Old 09-13-2010, 10:12 PM   #1
A_Vlass
Boyd Welding Gas Tank
So I bought a Boyd Welding custom gas tank for my 1969 GMC Shortbed that is built to go right behind the rear axle. I was wondering, other than the mounting kit which is included, what do I need in order to get this thing hooked up right? Is there a sending unit or any other fittings that I need?
A_Vlass is offline   Reply With Quote
Old 09-16-2010, 02:08 PM   #2
A_Vlass
Re: Boyd Welding Gas Tank
anybody...
Old 09-16-2010, 02:15 PM   #3
67C10BUB
67C10BUB's Avatar
Wish I could help, but mine hasn't arrived yet either.
67C10BUB is offline   Reply With Quote
Old 09-16-2010, 02:35 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
The way I understand it, it should come with the sending unit, roll over valve and all you should need to provide other than installing it is fuel line, which I believe is just 3/8' line, have you PM'd David?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-16-2010, 06:35 PM   #5
tubbedII
needs more $$$
tubbedII's Avatar
I installed one in my blazer. It came with the sending unit, but that was it. All I got was a tank and sending unit with two bungs welded in, one for the fuel and one for a vent (I'm not running efi). I had to buy fittings for fuel line & vent, fuel line, filler neck hose and a little motorcycle vent cap for the vent.
I didn't buy mine through a group buy, so I knew I had to get these parts.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 09-29-2010, 12:15 AM   #6
A_Vlass
Thanks for the help guys. I ended up figuring out what I needed. I forgot to order mine with the sending unit so I bought it separate. Had to buy the fittings as well.
Old 09-29-2010, 12:20 AM   #7
Robertjust777
i got mine and for got the sending unit also and fittings but ya everything worked fine. went with a 1/2 inch line for more fuel but ya. and got my fuel sending unit online
Robertjust777 is offline   Reply With Quote
