Old 09-14-2010, 02:51 AM   #1
gastrader35
HOARDING SPECIALIST
gastrader35's Avatar
70 3/4 ton cab
i noticed in my catalog that a 3/4 ton cab mount kit is different than a 1/2 ton kit. my question is are the mounts the same on a 3/4 ton cab . i want to use the 3/4 ton cab and clip on my 1/2 ton shortbed frame.
gastrader35 is offline   Reply With Quote
Old 09-14-2010, 08:22 AM   #2
mdwilf
mdwilf's Avatar
Re: 70 3/4 ton cab
the cabs are identical - the rear cab mounts are lower on the frame on 3/4 frames, so the mounting kits for 3/4s have taller bushings or extra bushings.
What I do in my spare time:
http://rosebudsgarage.shutterfly.com
mdwilf is offline   Reply With Quote
Old 09-14-2010, 11:33 AM   #3
gastrader35
HOARDING SPECIALIST
Re: 70 3/4 ton cab
Thanks for the info. I thought they was the same but i wanted to make sure before i started the build.
