Old 09-14-2010, 06:32 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
What sparkplug wires/cap/rotor to get?
I have who knows how old wires/cap rotor. I plan on replacing them.
I heard on here somewhere that mid 70's vette wires are good because they are a lil longer?
Im planning on putting a 'curve kit' in the dizzy also
355 vortec
12* btdc(initial)
500 edelbrock 1 3/4 turns out
not impressed with power at all lol
My machinest said to worry about the advanced timing (full vacumn at like 2200-3k)?
Im going to check that now (34* at 2200rpm)
John
1999 Toyota Tacoma 4x4
Old 09-14-2010, 06:43 PM   #2
red69ss
Burnouts are therapeutic
red69ss's Avatar
Re: What sparkplug wires/cap/rotor to get?
I use AC delco plugs, I like taylor wires, but recently I used msd streetfire wires on one of my old cars and am pleased with them so far(you have to make these up yourself but it comes with the clamp and is simple to crimp ends on), I ordered them from jegs but seen that my local o'rielly's carries them in the store ( I think they will only work on hei dist.) ....as far as cap and button I always just get them at the local parts house. good luck
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 09-14-2010, 07:01 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
There are different quality levels of plug wires. I bought some Wilkinson's when I was in Tucson, because the station recommended them. I've bought bulk wire (stranded-core) and made my own. I've bought the cheap stuff where you had to assemble them to have a cheap set. You get what you pay for, and that applies to the result.
I'd go with an 8MM wire, that is a radio suppression wire so it won't interfere with your radio.....or your neighbors TV. I was introduced to Standard Blue Streak components by one of my favorite uncles....a long-term mechanic. But, I don't use points and condensor any more, so it doesn't matter. I have an ACCEL HEI on my truck, so the cap and coil are ACCEL. A good brand of cap...and you can do an eyeball comparo....will show you differences in quality. The cheesy cheap crap isn't worth taking out of the box. I like NAPA/Echlin stuff for rotors and caps.
Member Nr. 2770
Old 09-14-2010, 07:42 PM   #4
oldblue1968chevy
I dont wanna buy junk. Ive seen MSD brand cap/rotor at parts store?...
Plug wires, Id like to get something over the counter at the parts store also, but COULD order from jegs.
John
Old 09-14-2010, 07:48 PM   #5
oldblue1968chevy
Pulled dizzy to see if anything was broken or stuck.
Part of the rotor white plastic was broken?..(dunno how important, i assume i get a new one with the rotor/cap kit)
Springs werent broken or anything, ive got the 'curve kit' but need some help, ive attached a pic of the instructions, I want 34*, its not listed on the paper?..
thanks
edit, how much play should the weights have (up and down) they have quite a bit?..
John
Old 09-14-2010, 07:49 PM   #6
oldblue1968chevy
ooops forgot, heres the pic of insturctions with curve kit
John
Old 09-14-2010, 08:09 PM   #7
guyryan100
guyryan100's Avatar
I just installed Taylor 8MM wires last weekend. They have to be cut and the boots put on, took about 2 hours to install.
guyryan100 is offline   Reply With Quote
Old 09-14-2010, 08:13 PM   #8
oldblue1968chevy
^Just red X's man, Im sure it looks good though!
What're these 'taylor wires' gonna cost, im sorta on a budget (trying)
John
Old 09-14-2010, 08:15 PM   #9
cparman
sharp as a marble
I have used Taylor wire on a bunch of my old car customers cars. They have the end going to the spake plug made, and you need to finish the end at the dizzy cap. I have a crimping tool I have since I was a kid that I use to finish the ends. On both of my trucks, I have these wires. I run them like on a mid 70's vette. The front two on both side are run thru the motor mount, and are hard to see when installed. i will look for a pic so you see what I mean.
cparman is offline   Reply With Quote
