Old 09-14-2010, 08:16 PM   #1
GASWAGON
AMERICAN IRON ADDICT
72 big block mounts?
I took these out of a 72 rolling chassis I bought. Are these big block mounts?
The truck had a 454 in it but P.O. installed it in place of the small block. Any ideas? Thanks
GASWAGON is offline   Reply With Quote
Old 09-14-2010, 08:17 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: 72 big block mounts?
Those are not the factory 72 only big block mounts.. they are 73 up mounts which will work in the 72's by drilling a couple of holes..
Livrat is offline   Reply With Quote
Old 09-14-2010, 08:24 PM   #3
GASWAGON
Thanks for the info, I appreciate it. Jason
Old 09-14-2010, 08:24 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
Those are the same mounts we used out of a '73 C-20 when we put the 454 in my '71.
We did have to drill some holes in order to use them since when the engine was mated to the transmission and settled into the frame had no holes that matched.
It turned out good though and allowed the right distance from the fan clutch and radiator. There also was plenty of room at the back between the valve covers and firewall.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
