Old 09-14-2010, 10:06 PM   #1
buildinga55
radiator shroud question
Anyone put an aftermarket shroud on a 48? My 350 is all mounted and I am moving along with the build, however, ran into a little issue tonight. The front clip is off the car, engine mounted I put the radiator on so I could cut the hole in the new shroud and noticed the fan is positioned really low, infact the bottom of the fan is a little below the bottom of the radiator. I might be able to grind around on the radiator shell and get the radiator a little lower in so the fan would line up better. Or I could use an electric fan, but I would rather use my clutch fan. Any of you ran into this and have any advise? Thanks for the help
buildinga55 is offline   Reply With Quote
Old 09-15-2010, 01:56 PM   #2
panelrodder81
Doin' it live!
panelrodder81's Avatar
Re: radiator shroud question
I bought and used the shroud on from the Brothers Trucks for the 47-55 1st. You can cut the hole for your fan anywhere you want to put it, provided you are running an electric fan I suppose. I've had the thing on now for about a month and did a 300 mile plus road trip in the truck this past weekend and it worked perfectly and held up very nicely. Only thing I wish they had done is put some type of mounting system on it. I ended up riveting some mounting straps to it. I will see if I can get a pic... though it is rather tight and probably won't show you much!
-Panelrodder
1953 GMC Panel truck - 'Curly'
1961 Chevy Suburban - 'Larry' - Sold
2005 Harley Sportster - 'Shemp'
panelrodder81 is offline   Reply With Quote
shroud fan
