Old 09-14-2010, 10:18 PM   #1
Davetopay
Some leaf spring tech for off roaders and tinkerers...
http://littlekeylime.com/MrN/mrnimages/leaf_springs.png
I was looking around for possible junkyard swap front springs for my truck, and I came across this little gem.
Don't know if anyone will actually use it, but I found it interesting.
For instance...
a 67-72 front leaf pack is 44 inches long, with the mounting point exactly mid length, or 22". The rated capacity for a k10/k15 is 1110lbs, width is 2.5" and has 0 arch.
Interestingly enough 76-86 CJ Jeeps could be had with a 44 inch long, 2.5" wide rear leaf spring with 7 main leaves and 2 helpers, has a half way axle mount like the GM spring, and a rated capacity of 1200lbs. These have a positive arch.
I'd have to get my hands on an actual spring to measure how much lift this would be worth, but it seems viable. Probably at least 4 inches of lift.
Your thoughts are welcome.
Davetopay is offline   Reply With Quote
Old 09-15-2010, 10:35 PM   #2
jrdv
jrdv's Avatar
Re: Some leaf spring tech for off roaders and tinkerers...
That is interesting! I think this link should be made into a linky for the 4x4 section. There is a lot a good info that I have not seen in one place before.
For instance, I recently bought a 1962 short stepside chevy 4x4, and there are no aftermarket lifts offered for these older trucks. With the provided link, I might possible find another lift that may fit this truck. I have too many projects in front of this one, but I will be referencing this link for info.
Thanks for posting it..
John
jrdv is offline   Reply With Quote
Old 09-15-2010, 11:12 PM   #3
Davetopay
John
It could be that you will need to have some made for your truck.
check here:
http://www.generalspringkc.com/index.php
