02-25-2003, 03:21 PM | #1 |
Location: Bondurant, IA but in Worcester, MA for school
Wiring an electric fuel pump????
Can anyone show/tell me how to electrically hook up an electric fuel pump? A wiring diagram would be sweet.
I got a Holley "Red" pump and was wondering if this is good enough or should I get a "Blue" fuel pump? What are the advantages/disadvantages of the two? Thanks HotRod
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
02-25-2003, 03:49 PM | #2 |
faster, faster, faster
Ground it to the frame where ever you mount it, and run a 12-14 gauge wire to a keyed power source at the fuse block with the properly rated fuse inline, and that's it. Easy as pie. Just don't forget the pressure regulator.
I'm going to Law School, wanna debate? It's good practice. |
02-25-2003, 04:35 PM | #3 |
my new 72 - Thanks. Holley says that you dont need a regulator for their "Red" fuel pumps but the "Blue" ones do and they come with one. Any ideas? Anyone?
HotRod
02-25-2003, 04:49 PM | #4 |
Yeah baby!
A red pump will cope well with any street use. I run one on a 13 second truck with no problems.
I source the electric through a low oil pressure switch so that if the engine stops so does the fuel pump. These are available at Summit or other race shops. It looks like a normal oil pressure sender but with three terminals. It includes wiring instructions. As I have a rear mounted battery I am considering using a relay, at the moment it takes the full load from the pressure switch. Pressure regulator is not necessary with a red top. If you did have fuel supply problems with this pump try increasing the fuel line size. Think volume and not pressure.
11.37 @116 |
