09-15-2010, 12:10 AM | #1 |
throttle linkage
I have already done a search and did not come up with much to answer my question. my truck is a 1960 I have a 350 with edlebrock carb. what do I need for throttle linkage to make the stock pedal work. pics please.
09-15-2010, 12:42 AM | #2 |
60-66 Nut
Re: throttle linkage
I have yet to use this, but I'm reasonably certain it would work on our trucks.
http://www.jegs.com/webapp/wcs/store...Term=555-15795
09-15-2010, 10:50 AM | #3 |
This linkage rod is two pieces...one end screws into the other, thus it is adjustable for length. It's a reproduction part for a 67 Camaro with 396.
09-15-2010, 12:15 PM | #4 |
It's Better With Nitro
...very similar to the style of linkage in the previous posts, I fabricated mine from some left over ball/swivel and tubing parts. My linkage has several holes that uses a pin to secure the inner and outer shafts for larger adjustments, and the ball/swivel ends are threaded for finer adjustments.
09-15-2010, 01:09 PM | #5 |
Senior Enthusiast
I’m running a pair of the following cheapy heim joints, with a piece of ¼” all thread connecting the two. Its been working fine for close to 20 years:
http://www.jegs.com/i/Mr.+Gasket/720/3812G/10002/-1 I use a socket head allen bolt for the pivots with safety washers should the heim joint break, then double nut the ends to allow setting the tension for a nice tight slip fit. |
