Old 09-15-2010, 04:40 PM   #1
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
63-72 LSx Cooling fan setup what ya got?
I am currently running an aluminum radiator with dual electric fans, doe sthe mechanical fan keep the engine cooler or? do you have a stock shroud?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-15-2010, 05:10 PM   #2
Ackattack
Ackattack's Avatar
Re: 63-72 LSx Cooling fan setup what ya got?
I have dual electric fans off an LS1-F-body. Driving down the highway my temps are ~170 deg.
You can adjust what temps the fans come on via the ECM if you have it set up that way. On my corvette it was very effective at maintaining the temps <200 while at the drag strip.
Ackattack is offline   Reply With Quote
Old 09-15-2010, 05:23 PM   #3
Clyde65
Clyde65's Avatar
The reason I ask is because when I stop or am real slow with traffic, the temp goes to about 210+. that is without the AC on. when I am moving temp stays at or about 185-195. So I wanted to know what everyone else is doing, also I dont have my shroud on either, just the two 12" fans, one on all the time, the other with AC on.
Clyde65
Rebuild of Clyde
support our troops!
Old 09-15-2010, 09:05 PM   #4
TR65
TR65's Avatar
Clyde,
I am running a 6.0 L LS2 (390 HP), 190 thermostat. I am running twin electric fans. The engine runs 190-193. The radiator cools so well that the fans never come on unless I just sit and idle for 5 min. or so (that is in high 90's South Carolina weather). Then one fan comes on for a minute, drops the temp 10 deg and stops. The fans are shrouded with pass throughs if they are not running.
No air conditioning but the install is beginning.
http://67-72chevytrucks.com/vboard/s...d.php?t=420322
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 09-15-2010, 09:08 PM   #5
tk-mpl
tk-mpl's Avatar
I got a 16" Hayden electric fan that is controled by the PCM. It seems to cut in and out at an idle. Haven't had a chance to drive it yet...
1968 short box stepside.
2007 5.3L 4L60, tuned w/EFI Live
2005 Silverado bucket seats.
Dominator 2600's all around.
Porterbuilt tubular control arms.
Magnaflow 3" dual exhaust.
tk-mpl is offline   Reply With Quote
Old 09-15-2010, 10:08 PM   #6
LEEVON
Moderator
LEEVON's Avatar
That seems about right, long as it maintains 210 and doesn't creep up.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-16-2010, 08:41 AM   #7
Shon
I am using LS1 Alum intake and dual fans from F-body. I have one fan programmed to come on at 210 and go off at 200 (I think been a while since i looked) and the other one is to come on at 215 I think, it never comes on. I do not have an 'shrouding', I have it just like it is from the F-body.
Driving is 194* (stock thermo) and when I get in slow/stopped traffic it creeps up to 210 and then that fan brings it back down. I was shocked it actually worked that well.
If you run a mechanical fan I think a shroud is needed, on all of the other swaps we have been involved in the shroud is a must, if we move to an electric fan and it will move enough air it will keep it cool. Sometimes with the Rockcrawling Jeeps we stick to the mechanical fan b/c of the slow speeds and beating the motors take, seems to work better and gives us more room to put a HUGE trans cooler up front which will have its own fan.
NOTE: stock these motors are set to run in the 200-210 range all the time so that is normal.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 09-16-2010, 10:38 AM   #8
Clyde65
Clyde65's Avatar
TR65, you and I have the same radiator and the same fans I guess.
Shon, I dont have a PCM that has the fans in it, at least I dont think I do, it is from a 2002 truck. My #1 fan is set to turn on around 190 but most usually it stays on, the other fan turns on with the AC.
Clyde65
Rebuild of Clyde
support our troops!
Old 09-16-2010, 10:41 AM   #9
Shon
All of them have the ability to control fans, just have to tell it to in the PCM.
What tells your fans currently to run if they are not controlled by the PCM?
Old 08-03-2011, 07:23 PM   #10
CamaroChris
Hey Shon, what pins in the pcm do you connect relays to to control the high and low fans? I'm also using the pcm to control the a/c.
I LIKE TRUCKS
1986 GMC Suburban Build Build link
1982 Chevy SWB 2wd Scottsdale, Build Link Sold
1987 Jimmy Build, Project Cheap A$$ Build Link
CamaroChris is offline   Reply With Quote
Old 08-03-2011, 07:45 PM   #11
Shon
u have to get the PCM pin outs for the year you are using and put pins in there.
Old 08-04-2011, 06:29 PM   #12
OKGMC4
OKGMC4's Avatar
Try this site...TONS of info on here on these and I found my pinout location in there somewhere...
http://www.lt1swap.com/wiringharness.htm
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
