Old 09-15-2010, 07:04 PM   #1
Jonboy
Slots go on anything!
Dually drop questions
After doing (quite) a bit of research, it looks like a 1/2 ton swap into my dually is going to be a considerable PITA. I started looking at pictures of lowered Duallies and they look good, but I have a few questions. Since I really have my heart set on having a CCSB 1/2 ton, that is the way I am still leaning. But....
-What kind of drop could I expect by doing a flip in the rear, and spindles and cutting the springs in the front?
-Will it stil be able to haul like stock, or at least a loaded car trailer?
-Is there actually room to do a flip and keep most of the springs? I don't think mine is already lowered at all, but the bump stops are lower than the top of the springs.
I have access to a SWB frame along with all of the 1/2 ton suspension, and already have a clean short bed. Would I be time and trouble ahead to just cut the rear of the SWB frame, and graft it onto the rear of the 1 ton frame I have now?
it is entirely possible I am overthinking things, but I am trying to keep downtime to a minimum. Any help, insight, or advise is appreciated.
1974 Jimmy- 5.3/4L80e/NP241
Old 09-15-2010, 08:14 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: Dually drop questions
it would need a c-notch in the back with the flip then you could hall anything like stock
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-16-2010, 01:35 PM   #3
SCOTI
SCOTI's Avatar
Treat the dually just like the previous 1/2 ton. Spindles & trimmed front coils; flip kit w/a c-notch in the rear.
Disclaimer: It's still going to ride like a 1-ton dually. Ride tech's rear dually 'air bar' set-up is an excellent investment here. Full capacity w/the ride of a 1/2 ton.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-16-2010, 02:29 PM   #4
Jonboy
I figured it might still ride like that. Consensus around our house is that it should have 2 rear wheels, not 4. I think I was losing sight of what I really want, thinking it would be a lot easier. I still want a 1/2 ton CCSB.
I was under it looking at the difference in the spring height, and the shocks. Id doesn't look like there is any clearance at all to do a flip kit.
Old 09-16-2010, 06:02 PM   #5
SCOTI
SCOTI's Avatar
Maybe build the compromise?? Check out Hills Hauler (Hills Hot Rod shop) or the CCSB build that cochino sold to ?? (drawing a blank @ the moment). Both trucks are CCSB 3/4 ton & look nice......
http://www.truckinweb.com/features/0...uck/index.html
http://67-72chevytrucks.com/vboard/s...d.php?t=410827
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-16-2010, 06:06 PM   #6
BigBlocksRule
Sidewalls on the tires have as much to do with ride as anything. Since I don't pull a 5th wheel or very heavy bumper hitch, I've gotten away from the 10-ply tires and started using LT highway tires. Made more difference than anything else I've tried.
BigBlocksRule is offline   Reply With Quote
Old 09-16-2010, 07:14 PM   #7
joe231
joe231's Avatar
not anymore
Name:  Trip to Hill's fall 2009 004.jpg
Name:  Trip to Hill's fall 2009 007.jpg
some days i wish my truck was still 8 lug, but the 8 lug suspension stuff is super heavy and I love the way my truck rides
CHEVY ONLY
Old 09-16-2010, 09:26 PM   #8
Jonboy
It looks like everything is different from single wheel to dual wheel anyhow, so it would still need to be switched out. That, and we have a 1/2 ton parts truck. I was planning on new bushings and all anyhow.
Old 09-16-2010, 09:43 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Another concern about staying 1 ton or 3/4 ton is availability of wheels. The one tons have a decent selection if you want to convert to 22's but the price goes way up. The 3/4 tons are pretty limited. Adam spent forever trying to find a wheel he liked.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-16-2010, 09:49 PM   #10
Hulk Will Smash
Hulk Will Smash's Avatar
I vote for you to do a 4/6 drop with spindles and springs up front and shackles and pull a couple of leafs out back. Keep it a dually and chop up a single wheel 3/4 ton for the wife!
'87 R30 Crew Cab Dually
It's 11 PM, do you know where your IAC pintle is?
Hulk Will Smash is offline   Reply With Quote
Old 09-16-2010, 09:51 PM   #11
Hulk Will Smash
(Sorry quick on the trigger)
You'll be hard pressed to find another dually this nice once you decide you really want a dually (because they're so badass). Great looking truck as it sits, by the way.
Old 09-16-2010, 10:01 PM   #12
cochino12
It followed me home?
cochino12's Avatar
Doesnt your 1 ton ride great? My dually rides better than my 03' 3/4hd. Keep it a dually, if you really want to tinker make it a short bed.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 09-16-2010, 10:26 PM   #13
Jonboy
I keep hearing this. Needs a little more road time, I think.
Adam, do you think a 700 is going to hold up in your truck? I keep hearing that it won't, but the step up to a 4L80E is pretty steep!
Old 09-16-2010, 10:45 PM   #14
SCOTI
SCOTI's Avatar
Gear Vendors.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-17-2010, 05:01 PM   #15
joe231
joe231's Avatar
I got an idea....
Why don't we swap trucks, then you can paint it whatever color you want and I could cut yours up
CHEVY ONLY
Old 09-17-2010, 06:01 PM   #16
Jonboy
No offense Joe, but I don't like your idea.
Old 09-17-2010, 06:05 PM   #17
joe231
joe231's Avatar
Fine!
CHEVY ONLY
Old 09-17-2010, 06:07 PM   #18
Jonboy
Nothing but love, bro!
Old 09-17-2010, 06:20 PM   #19
joe231
joe231's Avatar
My wife would kill me anyway, I'd be having your same dilemma about keeping it a dually
CHEVY ONLY
Old 09-17-2010, 07:55 PM   #20
twoodson
Jon I think it would look killer with a nice drop and some some Eagle dually wheels instead of the more expensive Alcoa's with the 10 lug i believe. Also I am going to get the Torque Thrusts tomorrow and I will get them to you either tomorrow or Sunday. Sorry about that bro. If you really want the ccsb, then i will keep my eyes open for you; do a google images search for chevy dually on 20 inch wheels or something like that and see what images come up. I am about to see what I can find that I think you might like.
twoodson is offline   Reply With Quote
Old 09-17-2010, 10:09 PM   #21
phishninmn
my vote is to go ccsb. Just because i need some motivation to get my done. I also started with a dually you can switch all the suspension in a weekend with a buddies help.
phishninmn is offline   Reply With Quote
Old 09-17-2010, 11:35 PM   #22
Jonboy
Triveno, I am moving this weekend. I will be back at work Tuesday. No rush. I am starting to lean toards keeping my truck whole, but I think our '87 SWB truck that was going to get parted may get a new lease on life.
