Old 09-15-2010, 09:48 PM   #1
68anniversary
Steering Column Seal
Before I have this column completely apart for no reason, can anyone tell me how to change the firewall seal at the end of the column? It is a 72 with auto. I am guessing somehow those levers need to come off but I haven't a clue how? Can anybody help on this?
68anniversary is offline   Reply With Quote
Old 09-16-2010, 08:28 PM   #2
68anniversary
Re: Steering Column Seal
Anyone?
Old 09-16-2010, 08:39 PM   #3
JimKshortstep4x4
The column has to be removed from the truck. If you disassemble the column and remove the shift tube it makes it easier to change the seal but I have stretched the seal over the lever(s) being careful not to rip the seal.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-16-2010, 09:21 PM   #4
68anniversary
The column is on my bench. I cannot get the turn signal switch out. It is hanging up on something. I took out the three screws but it seems like something is holding it in. I tried the stretch method and when it started ripping the seal I quit.
Old 09-16-2010, 10:53 PM   #5
70shortfleet
70shortfleet's Avatar
Remove the housing that is around the turn signal switch and it will make the removal of the switch a lot easier. The housing is held on by just a tight fit to the main body, be careful when removing and take your time!
70shortfleet is offline   Reply With Quote
Old 09-16-2010, 11:01 PM   #6
slikside
slikside's Avatar
When I pulled my turn signal switch my column was still in the truck, along with the steering shaft. It was difficult and took a lot of fiddling but I got it out in one piece. Make sure you push the hazard signal button in. This will give you more clearance when trying to get the turn signal switch out. But with this thing on your bench, I would imagine you have more room to work with.
slikside is offline   Reply With Quote
Old 09-17-2010, 12:10 AM   #7
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Now that you have the 3 screws out turn upper housing with switch counter clock wise and it should all slide out together.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
