Old 09-16-2010, 04:02 AM   #1
Hazieview
Building Dreams out of Dimes!
Will this DUI HEI work on my sb400
Hey guys I need to get a new HEI and I was looking at the Davis Unified Ignition GM Street/Strip D.U.I. Distributors
The sb400 is only good for 6000rpms max. I have a mild street/strip setup.
Thanks!
Hazieview is offline   Reply With Quote
Old 09-16-2010, 04:15 AM   #2
HOGDADDY
HOGDADDY's Avatar
Re: Will this DUI HEI work on my sb400
Excellent choice btw I have purchased 3 of these over the years with no problems at all. You can even order them directly custom calibrated to your engine. http://www.performancedistributors.com/
HOGDADDY is offline   Reply With Quote
Old 09-16-2010, 07:33 AM   #3
silvereagle07
silvereagle07's Avatar
I think I am going with this brand distributor as well. I've heard good reviews about them latley.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 09-16-2010, 04:35 PM   #4
jrcaprai
They are Great... I actually converted a stocker over to all the DUI parts at one time, worked really good
jrcaprai is offline   Reply With Quote
Old 09-16-2010, 09:47 PM   #5
DubDubU
DubDubU's Avatar
Mine works great.
Just a side note: if it ever breaks, like on a road trip, stock hei parts from any parts store will get you going again.
'79' shortbed
DubDubU is offline   Reply With Quote
Old 09-17-2010, 05:44 AM   #6
Hazieview
Thanks guys! I I have read a lot about the distributors and I think this one is my best bet.
Can anyone elaborate on the vacuum advance. Such as why do some trucks have it and some trucks dont? Why is it good for a street truck etc.
Thanks again!
Old 09-17-2010, 06:22 PM   #7
DubDubU
DubDubU's Avatar
This is a quote from an article I once found online. This was the easy to understand part.
by Lars Grimsrud
Colorado Corvette Crazies
The Ultimate Corvette Tuning and Beer Drinking Fraternity
Lafayette, CO
"But in general terms, most GM V8s will produce
peak power at WOT with 36-38 degrees of ignition timing. Peak fuel economy and drivability at cruise is
achieved with about 52-54 degrees of advance. Best idle quality has a much wider range depending on cam
& engine, but tends to be in the 12-24 degree range. Lowest emissions usually occur with timing in the 4-8
degree range."
'79' shortbed
