Old 09-16-2010, 10:20 AM   #1
TonyJohnson
TonyJohnson's Avatar
Question on sport bumper setup
My Blaze came with a custom channel-beam rear bumper and I'd like to go back to a sport bumper. Is there any difference between the rear mount brackets for the Blazer and the fleetsides? Somewhere I read that the blazer just uses 2 brackets instead of 4? Anyone have the skinny on Blazer bumpers?
I'm also looking for the best receiver hitch for a 4" lift Blazer with sport bumper. Class III or better.
Thanks, Tony
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 09-16-2010, 01:24 PM   #2
drunkbus
New Member
drunkbus's Avatar
Re: Question on sport bumper setup
The bumper on the Blazer bolts directly to the end of the frame rails and has 2 brackets. A lot of them like mine have had the rear frame rails cut off to mount different rear bumpers. I think you can use the truck brackets if this is the case.
drunkbus is offline   Reply With Quote
Old 09-16-2010, 01:25 PM   #3
TonyJohnson
Thanks.
Tony Johnson
Old 09-16-2010, 06:45 PM   #4
cleszkie
cleszkie's Avatar
If I'm not mistaken, all pre 72 Blazers lacked the rear frame horns for bumper mounting. It was only the 72s in which the rear frame horns were extended all the way to the bumper. Someone correct me if I'm wrong on this (I could be wrong with the year of the changeover).
cleszkie is offline   Reply With Quote
Old 09-16-2010, 08:22 PM   #5
Bentblazer
Bentblazer's Avatar
My 71 had the brackets only, no frame horns, and believe its stock.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 09-16-2010, 08:25 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
69-71 require 4 brackets
72 require 2 (outer only) brackets
Keith
Convert to disc brakes.
