Old 09-16-2010, 11:12 AM   #1
Mark B
Mark B's Avatar
salvage for transmission
I plan to change my inline six powered 1970 C10 from a 3 on-the-tree to an automatic.
Last weekend I bought a donor truck which has a six and an automatic transmission. Oh, and it has power steering which I want also.
I am going to flatbed the donor to my local garage and have them pull
Engine, and accessories
Transmission
Transmission x-member
Drive shaft
Steering column
Powering steering pump, brackets, and steering box.
Do I need the pedal assembly?
Anything else I need to salvage? After its all yanked the rest is going to scrap - so I have no second chances at it.
Pic is a Hudson Teraplane truck. Isn't it cool? My truck looks like any other!
thanks
Mark
Mark B is offline   Reply With Quote
Old 09-16-2010, 11:34 AM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: salvage for transmission
i would remove any part that you think you could use, or sell in the future to help fund your project...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-16-2010, 12:16 PM   #3
gkesseru
gkesseru's Avatar
The automatic truck will probably have a radiator with built in transmission cooler. Get the radiator and cooling lines. The pedal assembly without the clutch pedal would also be needed. This will be almost out if you are pulling the steering column. Need to disconnect the Master Cylinder or booster to release the pedal assembly. Make sure you get the neutral switch with the column.
Brings up an interesting question: Is the wiring harness different on an Auto vs the stickshift for the neutral switch? Likewise for the reverse light switch.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 09-17-2010, 02:49 AM   #4
raycow
Don't forget the shift linkage, kickdown cable, throttle linkage and speedo cable.
Ray
raycow is offline   Reply With Quote
