cut coils question
ok, i dont want to start an argument, but...until i can afford drop springs , how many coils can i safely cut from the front of my 66? also, how much drop per coil can i expect? could you guys post pics of your trucks and tell me how many coils u took so i know what to expect. thanks all!
Posted via Mobile Device Posted via Mobile Device |
Re: cut coils question
I put in a 78 front suspension in my 62 and cut out 1 coil, its seemed to drop it about 2 inches, and it rides great.
1-coil cut yields 2-3" of drop depending on the age/history of the springs. I would not cut more than one coil off of OE truck set-up springs. Any more & the coil is short enough that it can dislodge when the suspension is extended.
Rottenwood Garage Member..Yes!
budget!!!! Ride wasn't bad for price... 1 1/2 coils cut... wrangler tj springs in back...
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way. My 65 (SOLD) http://67-72chevytrucks.com/vboard/s...d.php?t=317013 My 51 (SOLD) http://67-72chevytrucks.com/vboard/s...80#post3551880 Racetruck III (SOLD) http://67-72chevytrucks.com/vboard/s...72#post4254972 Rottenwood Garage and Speed Shop.....where everything must be racy! Gone to dark side for a while...1966 F100 in the stable ![]() |
made in america
i cut 1 and a half coils for exactly 3 inches of drop up front. if i had shocks that worked it would ride like a dream.
http://s796.photobucket.com/albums/y...9.jpg&newest=1
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes. sounds good 1964 c10-283 powerpack, 3 on the tree ![]() 2004 corvette- lowered, borla, tuned. slow ![]() my old girl 1966 c10- 305v8, t-5 sold Last edited by 66redw/white; 09-17-2010 at 09:32 AM. Reason: frigen picture! |
and a few others
My 63 which I sold last year. 1.5 coils cut in front and 70 Chevelle rear springs.
I did have to cut the bump stop brackets off the lower control arms though. ![]() ![]()
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi Last edited by 63 & 64 Bowties; 09-16-2010 at 04:54 PM. |
1.5 cut off the front is the max I would want to go. I also cut out the bump stops up front, and bought some decent short shocks and I ride really nice up front.
Rockin' a '66 and loving every minute of it ![]() |
i recently just cut mine 1.5 in front. havent put my front suspension back together yet. but cant wait to see what it will look like. I wont be able see how it rides until the new motor is in
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
#9 | |
![]() I cut 1 coil out of my 66 and it was off by a bit so I took another 1/4 off for a total of 1 1/4 coils. This was a net of 3" drop for mine. I did not have to remove the metal portion of the bump stops but i did remove the rubber and install new shocks. It has been on the road for 2 years now with this set up and have had no problems.
66 short wide fleet sbw = Gave to my best friend 66 short wide fleet bbw |
Happy to be here
![]() Join Date: Mar 2000
What all these posts tell me is Scoti is right on the money. If your not sure what you want, start with one coil and go from there. If you do decide the first cut isn't enough be sure you drive it first before you make another cut. Just setting it back on the ground does not unload the suspension and allow it to settle.
Not that I would ever do something dumb like cut another coil "before" I test drove it..... ![]()
#11 | |
please, more info on the chevella rear springs. are they a direct fit? i used to own a couple A bodies, i probly still have a set or 2 still sitting around. thanks for all the help guys!
#13 |
and a few others
The Chevelle springs were a simple bolt-in. Just use the same factory mounts for the pig-tails. The ones I used were from a SBC 2dr car and not new.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
