Old 09-16-2010, 07:05 PM   #1
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
What is this? (gm part)
Trying to clean out my cache of things I will never use so I can maybe one day get my suburban on the road.
Anyway I found this it seems like a gm accessory, I remember it being in an orignal box but I didn't store it well enough so that got ruined. The guy I got it from was a 55-59 collector so it is most likely from that area but don't know for sure.
whoever can identify this will win title as bestest identifier of odd gm parts master. Now who wouldn't want that?
68SWB4x4 is offline   Reply With Quote
Old 09-16-2010, 07:07 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: What is this? (gm part)
It is a very hard to find windsheild washer bottle and pump from the mid to late fifties GM
dwcsr is offline   Reply With Quote
Old 09-16-2010, 07:23 PM   #3
cdowns
cdowns's Avatar
yep and they r worth some good money to the restorers//ebay it you might b surprised
Old 09-16-2010, 07:26 PM   #4
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Nice, thanks guys, the guy I got these parts from was a crazy 55-59 chevy truck collector, I am pretty sure this one is/was NOS in the original box but I screwed up and didn't store it right. I guess I will move this to WIW's as I intend to sell it.
This board has and will always be the best.
Old 09-16-2010, 09:07 PM   #5
DANTIP
DANTIP's Avatar
I recall seeing those on full-size Buicks in the 60's.
DANTIP is offline   Reply With Quote
Old 09-16-2010, 09:40 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I'm having a flashback to the time when I was pumping gas in '66 at an ESSO station. Cadillac comes to mind, but it could have been Buick, Olds or Pontiac. Never saw one on a Chevy....but doesn't mean it couldn't have been on one. Oh, not on a mid-sixties, but a mid to late Fifties, with the 55-58's seeming to be what I remember.
Member Nr. 2770
Old 09-17-2010, 01:23 AM   #7
magicoolbus
magicoolbus's Avatar
Definately out of a 55-59 chevy truck. Well at least the bracket is. The jar and lid were used in many GM products. The lid type is for a vacuum type of actuation. The one I have for mine is actually a foot pump pedal. Here's a shot of the installation instruction, a foot pump and a NOS washer jar and lid
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 09-17-2010, 03:18 AM   #8
raycow
You are definitely in the ballpark with mid to late 50s. Later ones had plastic reservoirs and earlier ones had a different pump design. The problem is that similar bottles were used by all GM divisions with only very slight differences. Non-GM cars had similar ones too, because they were made by Trico, an outside supplier to most of the OEMs.
The survival rate on these is low unless the car lived its whole life where the temperature didn't get down below freezing. A lot of owners were lax about adding sufficient antifreeze to the water.
Ray
raycow is offline   Reply With Quote
Old 09-17-2010, 05:52 AM   #9
maxwedge528
i was under the hood of a very original 55 cadillac sedan deville yesterday and it had a similar glass jar! windshield cleaner reservoir? as a matter of fact there was a gm label advising the owner to empty the bottle in the winter or to mix the water with GM something or another to prevent freezing. also surprising that the manual fuel pump was installed on the top of the motor kinda of in the area of the water neck to the top radiator hose.
maxwedge528 is offline   Reply With Quote
Old 09-17-2010, 05:03 PM   #10
raycow
Those washer bottles were more common on the higher priced cars than on Chevys. They might have been standard equipment or maybe that class of cars was just more heavily optioned as a matter of practice.
Cadillac wasn't the only engine with a top-mounted fuel pump. The Ford flathead had one and it was infamous for being prone to vapor lock. I don't recall hearing those stories about the Cad though. Maybe GM engineering was better?
Ray
Old 09-17-2010, 06:33 PM   #11
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Thanks for all the info, this weekend I am hoping to clean it up and get some better pictures, I have some other unique parts laying around that need identifying as well
Old 09-17-2010, 08:30 PM   #12
Jwill41
Jwill41's Avatar
looks like a moonshine runners pee jar
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
