Old 09-16-2010, 09:07 PM   #1
GobbleStalker
GobbleStalker Calls
GobbleStalker's Avatar
Rearend diff question.
Is there any way to tell the gearing in the rear end without taking it appart. Also I do not know if it is posi or not. Truck is running but not well enought to burn the tires. Motoer getting ready for a rebuild. Any help is appreciated.
Kev
GobbleStalker is offline   Reply With Quote
Old 09-16-2010, 09:37 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Rearend diff question.
With it jacked up, or on a rack....mark a reference point on the tire (or remember where you started)..then turn the tire one full revolution while you count the number of times that the rear u-joint turns. If the tire turns one time and the u-joint turns just a hair over 4 turns, it's probably a 4.11.
Member Nr. 2770
Old 09-16-2010, 09:49 PM   #3
jcis4me
jcis4me's Avatar
So if the drive shaft turns 3 times? 3.08?
Marty
jcis4me is offline   Reply With Quote
Old 09-17-2010, 02:27 AM   #4
raycow
Close, but no cigar.
Put matching marks on the pinion yoke and differential housing. Jack one rear wheel off the ground, put the transmission in neutral, and the parking brake off. Turn the wheel exactly TWO revolutions and count how many times the driveshaft turns, estimating any fractional turn as closely as possible. That number is your axle ratio.
If the wheel is difficult or impossible to turn, you may have posi. In that case, jack both rear wheels off the ground and turn either of them only ONE revolution. Count the driveshaft turns the same way as for an open rear.
Ray
raycow is offline   Reply With Quote
