Old 09-16-2010, 11:16 PM   #1
kgmunro
65 suburban diff replace
My suburban has 6 lug diff right now. Can I just replace axles to make it 5 lug pattern (73-87 chevy pickup)? If so what axles will fit? Or should I find a diff from....??
kgmunro is offline   Reply With Quote
Old 09-17-2010, 01:03 AM   #2
Captainfab
60-66 Nut
Re: 65 suburban diff replace
You cannot just change your axles for ones from a '73-'87 truck. As I mentioned in your other thread, the '71-'87 differentials are 1.5 inches wider, so the axles are .750 inches too long. To change to 5 lugs you can either look for a '71-'72 pickup rear differential which will bolt right up, get a '73-'87 rear differential and change the mounts, or lastly buy aftermarket 5 lug conversion axles. This subject has been discussed many times. A search should provide many posts of info on the subject.
Old 09-17-2010, 06:14 AM   #3
kgmunro
Thanks Captainfab, I am used to working on camaros, this is my first 65 suburban/truck rebuild so I might have alot of stupid questions.
Old 09-18-2010, 12:29 AM   #4
Captainfab
60-66 Nut
I wasn't trying to imply that this was a stupid question. Everyone has to learn somehow.
Old 09-18-2010, 03:05 PM   #5
kgmunro
If I install a diff from an 85 1/2 ton, are the spring perches in the right spot or do I have to weld them in a different spot?
Old 09-18-2010, 07:10 PM   #6
raycow
Assuming your 65 has rear coil springs, you MUST weld the trailing arm mounts onto the 85 axle housing. You can't use the stock 85 spring mounts because the trailing arm mounts sit at an angle to the housing.
Ray
raycow is offline   Reply With Quote
