Old 09-17-2010, 08:54 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
LS Stroker kits
If I want to make some power with a stroked 6.0l and a little help from a turbo, who would be the best company to get the components from? Callies? K1? Scat? I am thinking something in the low 400 ci range. What is the max power/boost level for an iron 6.0l block?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 09-17-2010, 02:34 PM   #2
Shon
Re: LS Stroker kits
I normally will buy those parts from Scoggin Dickey.
I would look into a short block from them, I was looking at stroker kits and for the kit price I can nearly buy the short block....
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 09-17-2010, 05:12 PM   #3
Super73
Super73's Avatar
Re: LS Stroker kits
For you question on the Block, they have been known to handle over 1000rwhp. Heck, the stock crank has been above that mark on a ton of cars.
Let me ask you this, why do you want to go with a long stroke AND a turbo? How big of a turbo do you want to use?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-17-2010, 09:51 PM   #4
softballnrd27
Re: LS Stroker kits
What would you suggest? Is it a bad idea to stroke and turbo it? I am trying to find a good source to read up on what needs to be done to a motor to handle boost. I know a strong bottom end and lower compression than a n/a application.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 09-18-2010, 04:46 AM   #5
Super73
Super73's Avatar
Re: LS Stroker kits
If your gonna put boost to it, spend the $1000 you'd be spending on a crank and put it in to something else instead. Perhaps instead of buying a iron 6.0 go Alum LS3 block (6.2). I have seen Alum LS1's handle 1200+ rwhp. Just make sure there is a motor plate and mid plate.
Old 09-18-2010, 02:51 PM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: LS Stroker kits
If you're set on running a turbo...you would probably want to go with a big bore/short stroke short block...with a low (under 9.5:1) compression.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
