Old 02-25-2003, 07:32 PM   #1
theo70
COMING SOON...
theo70's Avatar
leaf spring lowering
I need some advice on how to lower the rearend of my 1970 SWB fleet. I want to go about 4", but the leaf spring is above the axle. A flip kit would drop it about 5 or 6, and I don't want to C-section just yet. Are there shackle and hanger kits for this app?
any help is appreciated
theo70
theo70 is offline   Reply With Quote
Old 02-25-2003, 07:56 PM   #2
my new 72
faster, faster, faster
my new 72's Avatar
You can buy new 4" lowered leafs for a few hundred bucks. It's the way I went and it's as easy as can be.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 02-25-2003, 08:04 PM   #3
crazy longhorn
Fabricate till you "puke"
2nd that, probably the slickest way to go would be a dropped leaf. They do have shackles kits, but i havent seen a front hanger kit for the 67-72..........crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-25-2003, 08:05 PM   #4
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Will thoes drop rear leafs fit on a 1970 C20 Custom Camper LWB? Cus I want to drop my truck as well. THanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 02-25-2003, 08:44 PM   #5
my new 72
my new 72's Avatar
They should. Give the guys at ECE a call, they'll hook you up.
Old 02-25-2003, 09:08 PM   #6
special70gmc
special70gmc's Avatar
no the leafs won fit a c20 i tried to get em but ECE told me the hangers are different ans so is the space between the axle and hangers.
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 02-25-2003, 09:12 PM   #7
HotRod929
HotRod929's Avatar
That kind of stinks. How bout if you swapped in C10 hangers? Would the drop leafs then work?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 02-26-2003, 03:47 AM   #8
HotRod929
HotRod929's Avatar
anyone???
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 02-26-2003, 04:03 AM   #9
Project1970
14.1 @ 96MPH
Project1970's Avatar
You could always go get the leaves re-arched...
Aren't the C20 leaves 2.5" wide instead of 2.25"? I wonder if you could use '73-'87 leaves...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 02-26-2003, 04:10 AM   #10
HotRod929
HotRod929's Avatar
Yes that would be nice to be able to use 73-up springs. Also where could I get my springs dearched here in MA? And how much would they cost get dearched?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 02-26-2003, 08:42 AM   #11
special70gmc
the c20 springs are 2.25 but they still wont fit maybe you can swap hangers tho good thing to try out they cant cost much to get ahold of you know
1958 belair 2door
Old 02-26-2003, 09:57 AM   #12
72MARIO
72MARIO's Avatar
Any spring shop will do it I paid 20 bucks per side any drop you want.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-26-2003, 01:00 PM   #13
HotRod929
HotRod929's Avatar
Are the hangers the part that attach to the front of the spring (closest to the front of truck) and schackles attach to the rear of the spring right? What is so different about the C10 vs C20 hangers? Thanks for the info guys
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 02-26-2003, 04:30 PM   #14
mastx
I found a place called www.performancesuspension.com that has lowering shackles for about $40. They claim they fit our trucks but I havent purchased or heard of anyone who has used them. They only give you a 2" drop, but you may try this in conjunction with something else to give you the drop you want.
Mario
Mario A. Santos
marioasantos@hotmail.com
Luling, Texas
1970 C/20 (in slow progress)
1971 Custom Camper Longhorn
mastx is offline   Reply With Quote
