Old 09-17-2010, 10:13 AM   #1
canadian trucker
A day should have 30 hours.
My truck frame is *&^%#@ Please Help...
Hi guys,
I'm in need of some help of your expert advise, experiences and out of the box thinking.
The frame on my 84 C-10 SWB Truck is (in the mechanics words) f@*$#d.
The rear is rusted thru and cracked on the drivers side by the first cross member after the cab. I may be able to cut it out and weld in a new piece and brace it.
The front is bent do to a crash from the previous owner. The frame had been fixed and looked like nothing had happened, been driving it for 5 years since. But after removing my rad support mount bolts it twisted to the point of having to use the forklift at work to straighten it enough to put back together. The passenger side shock mount is also sheared off. (my fault)
I have plans for this truck, put this is coming at the wrong time.
The big question
What are my options ?
Any help is appreciated
Thanks in advance.
canadian trucker is offline   Reply With Quote
Old 09-17-2010, 11:11 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: My truck frame is *&^%#@ Please Help...
What the condition of the truck in general? Is it worth finding a new frame, or would you be better off finding another truck? In the relatively rust free South, we walk away from anything remotely rusted. In your region, it's not that easy to do.
If the body is in good condition, I would locate a clean frame and do the swap. Assuming you have the place, tools, and skills to do the job. If the body is going to need expensive repairs too, I would consider buying a better truck and using your for parts.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-17-2010, 05:39 PM   #3
canadian trucker
The rest of the truck is pretty good, little rust on the cab, doors dented a bit.
The frame is the weak link. Finding a frame here seems to be damn near impossible...
I have the place, tools and skill for the job. My biggest problem is time. The truck is my DD and I need it back up and running.
Anyone have the dimensions for a frame, I may just build a custom one and then transfer cab and box onto it.
Thoughts?
Old 09-17-2010, 06:22 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Here is one for a...4X4
http://dallas.craigslist.org/mdf/pts/1928434430.html
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-17-2010, 06:31 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Other than it being 2200 miles away from him, that might be a good deal.
Originally Posted by canadian trucker View Post
....Anyone have the dimensions for a frame, I may just build a custom one and then transfer cab and box onto it.Thoughts?
If you have the ability to build one, you should have the skills to repair the one you for now. It may not be pretty, but patch it up and run it till you can locate a frame.
Yes you can build one, but that wouldn't be my first choice. I would look to the south of you for a rust free donor. Spend a weekend with a trailer and go get what you need.
Articles-
"Refining Sierra"
Old 09-17-2010, 06:34 PM   #6
Clyde65
Clyde65's Avatar
another one, maybe 2150 miles away...just trying to be helpful with CL.
http://gulfport.craigslist.org/pts/1921939806.html
http://huntsville.craigslist.org/pts/1921347043.html
http://carbondale.craigslist.org/pts/1912216573.html
Clyde65
Rebuild of Clyde
support our troops!
Old 09-17-2010, 06:53 PM   #7
dropd80s
dropd80s's Avatar
Thoughts?
Again like the other guys, Im a little biased being in Texas and could prolly get a frame for free But, building one from scratch is too much work, no matter where you're at.
dropd80s is offline   Reply With Quote
Old 09-17-2010, 06:55 PM   #8
canadian trucker
N2TRUX
Yeah, you are right I'll just patch the front together until it works again.
Then just take a nice long weekend trip looking at frames.
Clyde65
Thank you for the CL links, I forgot how plentyful these trucks are just south from me.
Up here they are rusting out.
thanks again
Old 09-17-2010, 07:11 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Do some research for areas South of you that don't salt their roads. I know Colorado is a long drive but they have dry air and use sand on the roads. I'm not sure about states closer to you, but it's the path I would take.
Articles-
"Refining Sierra"
Old 09-17-2010, 10:13 PM   #10
geezer#99
geezer#99's Avatar
Hey neighbour. Wanta go 4x4. Here's a possibillity. I could go look at it for ya!!!
http://www.usednanaimo.com/classifie...--Re-_12378652
geezer#99 is online now   Reply With Quote
Old 09-18-2010, 03:47 AM   #11
kaotics
Hey if your interested I'll have a bare frame in a couple weeks off a 82lwb I'm grabbing that I want the drivetrain and axle from,
also kijiji man found this one running driving but rusted box for 200$
kaotics is offline   Reply With Quote
Old 09-18-2010, 06:43 PM   #12
canadian trucker
Geezer#99
Thanks, but im trying to go lower not higher.
kaotics
i do not really want the hassle about shortening the frame.
Update:
the raer rust and area where the frame was craked is now fixed
But i have stumbled across this sometime you can not win
Name:  l spring efed.jpg
Old 12-29-2010, 04:34 AM   #13
bctom
Nice fab work. But by the looks of the scale on the frame I'd keep looking for a replacement. I bet if you can patch up and straighten the one you have you'd probably find shortening a long box pretty straight forward. Good luck.
P.S. What did your engine come out of ( a caddy I'm guessing). What trans? etc.
Thanks from the Okanagan!
bctom is offline   Reply With Quote
Old 12-29-2010, 11:47 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Geezer#99-i do not really want the hassle about shortening the frame.
It looks like your doing good work with what you have. With the skills you have, I wouldn't rule out cutting a LWB frame down if necessary.
Articles-
"Refining Sierra"
Old 12-29-2010, 02:23 PM   #15
canadian trucker
Thanks for the comments, well I got lucky, I found a new frame of a 79 for 500$ came with 2 new NOS doors and a good hood.
pic of the frame
Name:  new frame.jpg
pic of the engine
Old 12-29-2010, 02:32 PM   #16
canadian trucker
Oh and about the engine
Its a 4L 90 deg 32V 4 Cam V8 out of a Lexus mated to a TH350 with a custom bell housing and flex plate adapter.
Stock power 300hp and 300lb
Soon to get an M112 Jaguar supercharger (with twin water-air intercoolers)
or quad turbos
All going thru a 6L90 or a 6HP26 transmission.
Possibly ending in a independent rear suspension.
Thansk for looking.
Old 12-29-2010, 10:27 PM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
That not lucky, that robbery. You stole that stuff..
Articles-
"Refining Sierra"
Old 12-30-2010, 12:50 AM   #18
edflores
or quad turbos
Thansk for looking.
SC400 motor? Thats the most original power plant I've heard of going in a Chevy
edflores is offline   Reply With Quote
Old 12-30-2010, 02:20 PM   #19
canadian trucker
I would never steal, wait would I?........ no never.
I got lucky, found a whole truck on craigslist. Had to drive out for 2 hours to get it, and I had to remove it that day. Came with a few extra (junk) parts.
All that on a trailer just big enough to haul the truck.
Old 12-30-2010, 02:23 PM   #20
canadian trucker
I know, there is like 100 of these swaps around, I knew I should have gone with something different. LOL
Here is a pic of the donor.
Was rolled up a lamp post at 130, with 4 people in it. All walked away. (well limped)
Old 12-30-2010, 05:57 PM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
Yeah, but I bet they all needed a change of undies.
Articles-
"Refining Sierra"
Old 12-30-2010, 06:43 PM   #22
canadian trucker
Oh no doubt, its also one of the main reasons I dont like lamp posts.
Old 12-30-2010, 06:54 PM   #23
Pop's C-10
Pop's C-10's Avatar
I like tha choice of powerplaint...
Pop's C-10 is offline   Reply With Quote
Old 12-31-2010, 04:45 PM   #24
canadian trucker
Thank you,
I hope it all turns out the way I would like it too.
Old 12-31-2010, 09:25 PM   #25
NZSquare
NZSquare's Avatar
Good choice on the motor, those are a pretty common swap in New Zealand aswell, lots of good info on them on NZ based forums if you need it.
What are you running for an ECU ? I had a Microtech, aussie company, ecu comes stock with dual ignitor channels.
I had a hilux (tacoma sized) 4x4 with one years back, went like a cut cat, all the way through to 10,000 if you let it. Another common mod in NZ is sticking an extra throttle body on the intake, the factory plenum chamber is known to be restrictive. Heres my old engine.
Cool project good luck with the swap.
NZSquare is offline   Reply With Quote
