Old 09-17-2010, 04:27 PM   #1
Silence86
Silence86's Avatar
Exclamation truck wont go into gear?
ok so today i was driving, and im at a red light and as it turns green i give it gas it starts to go and i hear a noise underneath the truck and all of a sudden the truck starts to rev up. i down shift to see if the truck put its self in neutral some how and it still wont go anywhere. i have to pull over with out actually driving it. the transmission goes through all the gears but nothing happens no reverse and no drive. it doesnt down idle when you shift into any of the gears....anyone know whats going on???
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622
Silence86 is offline   Reply With Quote
Old 09-17-2010, 05:33 PM   #2
primrrd
primrrd's Avatar
Re: truck wont go into gear?
I had a similar problem with the linkage inside of the transmission.
(dropped the pan and a bolt had fallen out) But in that case the truck was
not "free" shifting, it was stuck in low...
You may have had some of the external linkage come loose.
Follow it from the column to the trans and look for the problem.
If you find it, send up some pix for help!
primrrd is offline   Reply With Quote
Old 09-17-2010, 05:46 PM   #3
Silence86
Silence86's Avatar
i checked the external linkage and everything is fine. looks like i will be pulling the pan off tomorro
Old 09-17-2010, 06:28 PM   #4
Seven9er
Seven9er's Avatar
the pump might have crapped out.
USMC Former SGT 2002-2006
Oshkosh Truck Corporation- FSR, The worlds largest manufacturer of Severe Duty Trucks.
The Money Pit. http://67-72chevytrucks.com/vboard/s...d.php?t=406891
2009 2500HD R.I.P. http://67-72chevytrucks.com/vboard/s...12#post4025612
Seven9er is offline   Reply With Quote
Old 09-29-2010, 06:17 PM   #5
Copytron
what pump? Mine is doing the same thing. It worked when i parked it. Today I tried to back out and it wouldn't go into any gear.
Copytron is offline   Reply With Quote
Old 09-29-2010, 09:48 PM   #6
Restrorob
The One And Only !!!
Restrorob's Avatar
My 74 did the same thing the same way, Front pump took a dump....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 09-29-2010, 10:26 PM   #7
Silence86
Silence86's Avatar
had mine fixed turned out when i switched out the transmission i didnt replace the tc with the right one. so it eventually failed. my mechanic said i had a non lock up and i needed a lock up converter. got the problem fixed and now runs amazing
