Old 09-17-2010, 04:28 PM   #1
northerngmc
northerngmc's Avatar
Coolant capacity for a 68 C20 396
I purchased a 1968 C20 with a 396 this past spring. I am getting ready for winter ( it snowed about 20 miles west of town yesterday!) and tested the antifreeze strength in the old girl. It tested -25 C or about -10 F, which isn't cold enough. So I need to drain some out to get the strength up to -40 or colder.
So while I am at it I might as well drain it all, flush it out with water and refill with new antifreeze and a new thermostat.
So any idea what the capacity is of the complete cooling system (rad, hoses, heater and engine)? The truck is a 1968 C20 with a 396 and Turbo 400 with a trans cooler.
I have done some searching and seen anywhere from 2 to 4 gallons. Anybody know for sure?
I want to know the capacity so I can add antifreeze after the flush without over diluting it from the water left in the system.
Also are there drains in the block of a 396? I was searching and someone mentioned draining the block using the drains when doing a coolant flush.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 09-17-2010, 09:19 PM   #2
GruntMoanCough
GruntMoanCough's Avatar
Re: Coolant capacity for a 68 C20 396
The Haynes manual that I have lists 24 US qts. for your application.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 09-17-2010, 10:12 PM   #3
Sammy
24 would be with a 4 core rad.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-18-2010, 10:48 AM   #4
northerngmc
Thank yoiu very much, I believe it is a 4 core radiator.
Blaine
