Old 09-18-2010, 01:04 AM   #1
namkyoo98
Question about installing doors
I read on a website that doors off of an 86 Blazer will not work on an 86 Silverado. Does anyone know if they will fit on the Silverado??????
namkyoo98 is offline   Reply With Quote
Old 09-18-2010, 01:39 AM   #2
kurse1
Re: Question about installing doors
I may be wrong but what i was told at a few different places is that 77 or 76 + doors will work on all trucks minus the secondary doors on a crew cab or suburban. they should line right up but correct me if i am wrong if i have false info.
kurse1 is offline   Reply With Quote
Old 09-18-2010, 06:20 AM   #3
GM72K10
Next!
GM72K10's Avatar
As long as its a K blazer they most certainly will fit. Can't believe everything you read lol.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 09-18-2010, 10:24 AM   #4
bigblock73
yeller
bigblock73's Avatar
73-76, and 77-87 is the breakdown
bigblock73 is offline   Reply With Quote
Old 09-18-2010, 10:56 AM   #5
68 TT
Still plays with trucks
68 TT's Avatar
The 77-up square body front doors all interchange with no issues other than power window harness connector style relative to which fuse panel design you have, glass fuse or blade fuse.
The 73-76 doors were not designed to accommodate power windows but will fit the newer square body too.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
