Old 02-25-2003, 08:33 PM   #1
78customdeluxe
700r4
hey i have a 700r4 tranny and i want to make it so it will shift into overdrive when the pedal is near wot. i found this on the web http://www.kdsperformance.com/supdelcorser.html , i would prefer if i could get something at a parts store around instead of ordering something online. but i dont know what to ask for. thanks
Steve
1984 K20, will rebuild as a tribute truck to my high school 82 K20
1986 ElCamino (needs motor)
2004 2500hd LLY duramax
78customdeluxe is offline   Reply With Quote
Old 02-25-2003, 09:07 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
I think that police cruisers that came with 700R4's had a special throttle valve in them so it would stay in 4th at wot. I have no idea on the part number, but it was a stock GM part.
I also found this one.
http://www.superiortransmission.com/...mance/k015.htm
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-25-2003, 09:21 PM   #3
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Mine has no problem staying in 4th at WOT...am I missing something??
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 02-25-2003, 09:22 PM   #4
bagged78
world class smart ass!
bagged78's Avatar
Try looking here..
www.700r4.com
I belive the valve that Mike is talking about is for a Corvette, not sure thou.
Aric
75 2WD BLAZER (never ending project)
-some day maybe-
02 2500HD CREW CAB 4X (daily drive)
-8" lift 37s and 22s-
____ ____________________________
bagged78 is offline   Reply With Quote
Old 02-25-2003, 11:32 PM   #5
78customdeluxe
so what do you think about something like that link. if i understand right that diffrent sleeve and boost valve itself should let it go into overdrive am i right? i also thought the new servo might be good because i would like some more solid shifts too. but really im mad because i lost to a mustbang one day because it wouldnt shift into overdrive.
How hard is it for someone to put one of these things in? ive never been inside of a auto tranny before, i have rebuilt hydro drives in tractors before though if that makes any diffrence. can it be done in a day with only the basic tools? will the valve body have to come out? thanks
Old 02-26-2003, 12:34 AM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Word from the wise, before carefull installing the Vetter servo. I lost one 700R4 due to a bad installation. That's how I ended up getting my performance 700R4. The band clearance should be checked when the Vetter servo is installed. If it's too tight the tranny won't shift from 1-2. This will kill the tranny. If clearance is to loose then you burn the clutches. I would suggest installing the Vetter servo with the tranny out. Yes you can install it with no problems. I lost one 700R4 and I won't loose another one like that again. Too expensive.
Mike,
Thanks for the link. I like that 3-4 upshift at WOT. Kinda scary with a powerful engine. I would like to speed up in OD too. I really hate the kickdown on the part throttle. Installing the valve seems to be a very easy job. I'm still waiting to modify the governor too.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
