Old 09-18-2010, 09:49 AM   #1
oldtrux
oldtrux's Avatar
lower control arms
hi everyone i am putting the front end of my 66 back together and the a arm bushings dont seem to want to bottom out.there is about a 1/4 1nch of threads left.if i tighten them more they are very stiff and stay in the position you leave them in.(mind you i did not grease them yet).anyone familiar with these?thanks for any help...dan.
oldtrux is offline   Reply With Quote
Old 09-18-2010, 05:38 PM   #2
raycow
Re: lower control arms
Just to make sure we are all on the same page, the bushings are supposed to be tight in the arm and free to turn on the shaft. If you have unequal clearance on the front and rear, you may need to center the shaft in the arm. You will need to remove both bushings to do this. Center the shaft in the arm and then screw in both bushings equally.
Ray
raycow is offline   Reply With Quote
Old 09-18-2010, 06:04 PM   #3
Heater63
Heater63's Avatar
Isn't there a torque value for those bushings?
292 + TKO500
Heater63 is offline   Reply With Quote
Old 09-18-2010, 08:22 PM   #4
raycow
Yes, and I have seen it posted either here or on the 67-72 forum, but I don't remember the exact value. Hopefully, someone who has a shop manual will speak up.
Ray
Old 09-18-2010, 10:25 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I had saved that info and this is what is saved in my file.
140 ft/lbs for the pivot/bushing
The bushing should end up flush with the arm ridge. There should be no threads showing but at the same time, the cross shaft should be centered and not binding.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-19-2010, 09:30 AM   #6
oldtrux
oldtrux's Avatar
thanks for the help guys.i went out this morning and tightened the bushings right down,the shafts are centered.the control arms are definatleysome what stiff.when you lift them up they wont freefall..if you will.i guess once you grease them and get some weight on them they will free up...i dont know!thanks dan
Old 09-19-2010, 07:34 PM   #7
chevy_mike
chevy_mike's Avatar
Yeah, I found them not to free fall but even rubber bushing on the later ones don't free fall. They should have some stiffness to it but no hard. I had one that was hard to move and I just backed the bushings off just a little and it felt like the other side.
Since these bushings thread onto the cross shaft, you can actually pull the ends in a little and will put a little bind. Backing them off (like less than a 1/16th of an inch) can make a big difference.
Old 09-19-2010, 09:54 PM   #8
oldtrux
oldtrux's Avatar
yeh makes sense!thanks chevymike......dan
