Old 09-18-2010, 10:01 AM   #1
1-PU70
1-PU70's Avatar
Diffeence Between Integral Head & Non Intergal
So what is the difference between the two? Is one better then the other? What years where each made? I was thinking of looking for a streight 6 and want to be informed. Thanks Gary
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 09-18-2010, 10:43 AM   #2
LONGHAIR
Re: Diffeence Between Integral Head & Non Intergal
An integral head has the intake manifold built into the head itself. It is all the same casting. The earlier "non" integral head has the intake manifold as a seperate casting that bolts-on just like the exhaust manifold.
As a general rule, most guys prefer the non integral.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-18-2010, 10:43 AM   #3
fishingjred73
fishingjred73's Avatar
IMO I would look for the older model inline six. The intergral head come out in the late 70's I think. I know my 81 has one. The intake manifold is cast with the head so there's no changing them for any performance parts. Now I don't know if the head off a older motor will fit the new blocks as I haven't researched it.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 09-18-2010, 10:59 AM   #4
LONGHAIR
The integral heads started in '75, IIRC.
You can use either one, they interchange.
Old 09-18-2010, 01:40 PM   #5
Wrenchbender Ret
The intregal head came out in 75 like Longhorn say's although they didn't use it on Camero's & 292's. They were real bad about cracking the heads & ex. manifolds & broken bolt's in the ex. manifold. The head was ungodly heavy & burdened down with weird emission control gadget's. It's best to stay away from them.
Wrenchbender Ret is offline   Reply With Quote
Old 09-18-2010, 09:30 PM   #6
raycow
Don't let the above discourage you if you have the chance to buy an otherwise good engine with an integral head. As already mentioned, the earlier head is a straight across swap on any of the 63-up inline sixes.
Ray
raycow is offline   Reply With Quote
Old 09-19-2010, 10:05 AM   #7
1-PU70
1-PU70's Avatar
Thanks for the replys. Great Info.
