Old 02-25-2003, 08:48 PM   #1
LGCC10
Junior Member
Power Steering
I was wondering if anyone has ever put power steering on a 67pu that did not have the indentation on the frame. If so how did you do it? Thank you for everyones help already. But looking for more info.
Pete 67 c10 stepside
LGCC10 is offline   Reply With Quote
Old 02-25-2003, 08:54 PM   #2
Earl Junior
Cadillac power
Earl Junior's Avatar
I helped install PS on a truck without the indent. We used a torch, a couple of clamps, a chunk of solid steel and a BFH to make an indent.
I understand that you can space the gear box using washers, but that it takes away from the structural integrity of the steering column or something like that.
Fortunately, my 68 had the indent when I upgraded.
Just for the record, if I'm down to my last potato, I'm not sharing it with a guy who wants to kill me so he can get a better supply of virgins in paradise. That lesson is a little thing I call Economics 101, infidel style.
--Scott Adams author of Dilbert
Earl Junior is offline   Reply With Quote
Old 02-25-2003, 11:20 PM   #3
Kid
Kid's Avatar
I second Earl Junior's post. I put the indent in my 68 frame with a torch and a "big" ball peen hammer. Just dented it enough for the box to clear. Now I am still looking for a power steering pump and brackets.
Kid is offline   Reply With Quote
Old 02-25-2003, 11:29 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you use the washer method like mentioned, it makes it real easy to shear the bolts holding it on (through mechanical leverage) and also, the gear box is more likely to be turned by 1/2 tooth or so and that will wear hte gear very quickly.
Old 02-26-2003, 08:42 AM   #5
JimKshortstep4x4
Talking
GMC Paul has a kit for installing power steering in the 67-68 trucks. You may want to check it out. $59.95
Jim
Old 02-26-2003, 06:36 PM   #6
LGCC10
Junior Member
Thanks for the help everyone. Jim I'll check out GMC Paul, do you have the web site?
Old 02-26-2003, 07:00 PM   #7
Earl Junior
Cadillac power
http://www.gmcpauls.com/
Old 02-26-2003, 07:27 PM   #8
68 Suburban
68 Suburban's Avatar
Here is the exact page you will find it on:
http://www.gmcpauls.com/steering.htm
68 Suburban is offline   Reply With Quote
Old 02-26-2003, 07:44 PM   #9
JimKshortstep4x4
Talking
68 Suburban
Your avitar cracks me up!
Jim
