Old 09-18-2010, 08:03 PM   #1
evobuilder
evobuilder's Avatar
ok, power sterring belt routing question (not the same ol question)
I know that most people run the powersteering belt from the crank to the ps pulley..... but my question is, is there any harm in routing around the water pump as well? This is on a early 305 with a mid 70s PS pump.
Anyone have any knowledge on this?
Evobuilder / Seattle, WA
Hub Garage: www.hubgarage.com/mygarage/evobuilder
evobuilder is offline   Reply With Quote
Old 09-18-2010, 08:13 PM   #2
evobuilder
evobuilder's Avatar
Re: ok, power sterring belt routing question (not the same ol question)
how long of a belt should I run if I do go from crank to powersterring pump?
Old 09-18-2010, 08:59 PM   #3
Delmo
Delmo's Avatar
It's funny you post this. I actually ran into this today. I wanted to run the PS off the crank with a short belt but my P/S pully lines up with the second grove on the crank pulley so I figured I'd just go around the water pump. I looks fine with lots of belt on all pulleys. the other option was to get a 2 groove P/S pulley but I'm too lazy.
Delmo is offline   Reply With Quote
Old 09-19-2010, 12:32 AM   #4
Captainfab
60-66 Nut
I don't see any harm in doing this, but you'll just have to measure for the belt, and ask for a belt that length at your local auto parts suply
If you're running a '73 and up power steering pump with the long water pump then you just need a belt for that stock application.
Old 09-19-2010, 12:34 AM   #5
ConnDemned
I was just looking at this a few weeks ago, my 250 has the belts going on both crank & wp, but all the v8's were the other way. I would think it can't hurt, might even be a good idea, since you have 2 belts spinning the wp. Incase one belt breaks you will still have water circulating.
ConnDemned is offline   Reply With Quote
