Old 09-18-2010, 08:31 PM   #1
Pro Metal Shop
WIW 69 C10 Exhaust manifolds
Give me an idea what there worth, they came off a 69 C10 2wd but there smog equipped.
Thanks Steve
http://chevylegends.com/forum/index.php
Pro Metal Shop is offline   Reply With Quote
Old 09-19-2010, 05:45 AM   #2
JimKshortstep4x4
Re: WIW 69 C10 Exhaust manifolds
Around this area rams horn exhaust manifolds typically go for $15 each or $25 a pair in the condition that yours are in. Cleaned up, painted with the studs removed prices will be a little higher, $20 to $25 each.
Having the AIR injector ports does not seem to matter to most of the folks.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-19-2010, 07:10 AM   #3
Pro Metal Shop
Thanks Jim , if I have the time I may just acid dip them to make them a bit more presentable.
Thanks Steve
Old 09-19-2010, 09:25 PM   #4
Sammy
If they have the donut sleeves inside they are getting hard to find. Sure save the donut gasket's to last longer.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-19-2010, 09:32 PM   #5
Pro Metal Shop
Ya Sammy I will take it apart before I dip
Thanks Steve
