np205 swap
will a np205 direct bolt into a np208? my 87 keeps having problems with the 208 and i can get a 205 for a good price.
HUH??!!
J.T. 1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System. My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140 |
Re: np205 swap
#4 | |
Re: np205 swap
![]() Last edited by 81k10; 09-20-2010 at 10:39 AM. Reason: im an idiot |
Grease Monkey
Re: np205 swap
First, what trans do you have, 700r4? If so, then make sure the coupler you get matches your trans. All you MAY need is a coupler adaptor for the spline count difference. Advance Adaptors will have it. Count the splines on the input shaft on the 205 and then count the spline on the output shaft of the 700R. oh, one more thing you need to make sure the 205 came out of a truck with a th350. The mounting for a turbo 350 is the same for a 700r4. Good Luck
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
#6 | |
Re: np205 swap
Re: np205 swap
You need the 7Q-35A swap kit sitting on my end table....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
Re: np205 swap
how much money do you need to get it out of your way? lol
current trucks= -DD 90 RCSB 4x4 350/700r4 (green goblin) -87 RCSB 4x4 on 3/4 tons. 355/built 700r4.np208(soon to be 205). 10 bolt front 3.73s. 14ff rear 3.73s. 6inch suspension 3inch body. 37x12.50 Wrangler m/t military's. (sinister 13) Past 73-87s= -81 RCSB 4x4 built 350/SM465/205. 6inch suspension. 35x12.50 courser a/t's. 4.11s f/r (ravvid red) -80 RCLB 4x4 454/350/205. 6inch suspension 3inch body. 38.5 gumbos. (mudslut) 17 years old. have had 13 different vehicles. no wrecks. |
Re: np205 swap
PM sent
