09-18-2010, 10:35 PM | #1 |
It runs again
Only this time, with the 418ci motor I thought more cubes were suposed to tame cam shafts down Well, it's not the same exact cam, but not that much bigger
Old 243/250 New 245/260 Oh wait, the valve events are way different http://73-ls1.com/63truck/fire_up_exsmall.wmv
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 09-18-2010 at 10:37 PM. |
09-18-2010, 11:02 PM | #2 |
Re: It runs again
Sounds good man. Is it driveable yet?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
09-18-2010, 11:21 PM | #3 |
Re: It runs again
It'll be driveable with about 1 hours work. It moves on it's own power, just no front end on it.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
09-18-2010, 11:39 PM | #4 |
60-66 Nut
Re: It runs again
Music to my ears
09-18-2010, 11:54 PM | #5 |
#16876
Re: It runs again
Nice
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
09-19-2010, 03:46 AM | #6 |
Re: It runs again
I love it. Cant wait for your first run.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
09-19-2010, 12:51 PM | #7 |
Registered Truck Offender
Re: It runs again
Wow!, you beat me dude... Fired the 66 up last night, have to bleed brakes (re-did the whole brake system), wire the transbrake and throttle stop, run the valves and she is ready for a cruise around town. Oh,, and give it a bath. Been since FEBRUARY since I started this stupid project of a little 'motor swap'. (LOL)
Accumulated a few 'shop bruises' and a TON of dust, dirt, and sweaty hand prints along the way, but OMG does it sound wicked! Will have to see if the wife's digital cam-corder has a net friendly output format.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
09-19-2010, 01:02 PM | #8 |
Re: It runs again
Marv,
If it doesn't you can down size the video through Windows Movie Maker (That's what I did). I need to install the manual valve body and transbrake. When I do that, I'll also have to rewire the lock up. But, I will be taking it for a ride before any of that
09-19-2010, 04:01 PM | #9 |
Re: It runs again
Damn that thing sounds mad....Congrats.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
09-20-2010, 12:23 AM | #10 |
Re: It runs again
DOH,,, oil leak at the back of the intake. This sucks!!!
I moved the motor back into the firewall as much as I could without hacking the firewall so everything is EXTREMELY tough to get to back there,, really biting me in the arse!!!!! Oh well,,,, if it were easy.............................. It gave me a chance to tidy up all the wiring and start cleaning the filthy pig.
09-20-2010, 12:29 PM | #11 |
Re: It runs again
Marv, that does suck, but hey, what's another night or two working on the truck right??? When I originally put the motor in, we set it back as far as we could but didn't have the coil packs on the vavle covers. They barely fit on the truck. Then when I did the motor plate and intake swap, I raised the motor and that made matters even tighter. Good thing I raised it though, with the super vic intake and N20 plate, the air cleaner barely sits above that little lip on the cowl. It's like it was planed the whole time.
09-20-2010, 11:23 PM | #12 |
Re: It runs again
That LS motor sounds good!
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
09-21-2010, 12:41 AM | #13 |
Re: It runs again
Sounds very good.
68 chevy truck ls3, 418ci, pump gas 10.81@121.8 all motor. 1.47 60ft 70 suburban 350 tbi swap, 700r4, work in progress |
09-21-2010, 09:49 AM | #14 |
On a budget like Fred Sanford
Re: It runs again
Sounds excellent! Care to divulge the rest of the motor & cam specs? I think my next LS is going to be a 416ci.....
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
09-21-2010, 04:31 PM | #15 |
Re: It runs again
4.081 Bore
4" Stroke AFR 225 heads with light weight intake valves CTS-V lifters CM Push Rods Stock rockers Cam is 245/260 .646/.629 106icl 109lsa Super Victor intake NX 2 stage plate 4150 to dominator adapter Dominator TB 60lb injectors Dual Walbro 255 pumps Electric Water Pump ASP Under drive pulley Edelbrock 1 3/4 stepped to 1 7/8 headers with high velocity merge collectors for 4th Gen F-bodies (needs bigger headers). Dual electric cut outs (closed except last 5 seconds of video).
09-21-2010, 07:57 PM | #16 |
BAD BOW-Silverado XST
Re: It runs again
Show the engine!
09-21-2010, 09:41 PM | #17 |
Re: It runs again
I'll take some more pics when I get around it again, till then, here is a link of some build pics..
http://67-72chevytrucks.com/vboard/s...d.php?t=414860
09-23-2010, 04:16 PM | #18 | |
Re: It runs again
Thanks!!
