Old 09-18-2010, 10:50 PM   #1
GobbleStalker
GobbleStalker Calls
GobbleStalker's Avatar
Rear end help.
I just found out my truck is not posi and has 3.07 gears. I want ot make it a posi and am pretty sure I will want to change the gears to 3.55 ot 3.73's. What is the spline on these trucks. Can I put a 12 bolt camero gears and posi in or will they not match up?
Kev
GobbleStalker is offline   Reply With Quote
Old 09-19-2010, 02:33 AM   #2
raycow
Re: Rear end help.
The 12 bolt car R&P can not be used in the truck rear. You will need gears made specifically for the truck. The truck shafts (65-up) have 30 splines.
http://tomsdifferentials.com/catalog.asp?pg=10
Ray
raycow is offline   Reply With Quote
Old 09-19-2010, 06:32 AM   #3
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: Rear end help.
Have you ever set-up a rear before? Setting the pinion depth usually requires special tools...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 09-19-2010, 08:49 AM   #4
cdowns
cdowns's Avatar
Re: Rear end help.
if you buy the parts//posi,gears,bearings shims seals etc it's right around the $800mark
to me investing that much money it's worth the extra to have it installed by a pro for the few extra hundred
another option is to look for a 40year old junkyard piece and take your chances with a well worn $300-$400 piece
Old 09-19-2010, 09:35 AM   #5
LONGHAIR
Re: Rear end help.
Once again, cdowns is on it. "Pay a Professional"
Setting up a rear end is a very precise thing. It has to be done exactly right or it will fail quickly.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-19-2010, 03:21 PM   #6
GobbleStalker
GobbleStalker Calls
Re: Rear end help.
I would not be doing htis myself. Beyond my capabilities. Thanks
Kev
Old 09-19-2010, 03:30 PM   #7
Shaky
Shaky's Avatar
Re: Rear end help.
Kev
Well then - raycow is right, you can't use car parts in the truck rears. There's plenty of truck 12-bolt gears and posi carriers available.
Old 09-19-2010, 06:13 PM   #8
GobbleStalker
GobbleStalker Calls
Re: Rear end help.
So now the question. I am building the 350 to be between 300 and 350 hp. Have a 350Turbo trans. Should I stay with the 3.07 gears and just put a posi in or change the gears. I am afraid if I go to 3.73 I will rev around 4000rpm on the highway. Anyone have experience with this set up? I don't want the truck to be a dog of the line either.
Kevin
Old 09-19-2010, 08:19 PM   #9
LONGHAIR
Re: Rear end help.
It depends upon what you consider "highway speed" to be, and how much of the time you are driving that speed.
Old 09-19-2010, 08:23 PM   #10
GobbleStalker
GobbleStalker Calls
Re: Rear end help.
Highway speed here is 100km so 65mph.
Kevin
Old 09-19-2010, 10:24 PM   #11
Sammy
Re: Rear end help.
I'm going to make a wild guess...350 turbo..307 rear..60-62 MPH Maybe some where around 5500-5900 rpm?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-19-2010, 10:39 PM   #12
mixermike
mixermike's Avatar
Re: Rear end help.
my truck 350 motor,turbo 350,3.07 gears at 60mph = 2000 rpm. i had a 66 chevelle 396,4speed,373 gears at 60mph =3000 rpm.
mixermike is offline   Reply With Quote
Old 09-20-2010, 12:49 AM   #13
MudBug
MudBug's Avatar
Re: Rear end help.
If your gong with all new stuff, go with a 3.42 gear set and good differential.
Also like it has been previously said, let a pro put the rear end together.You will save money in the long run.
MudBug is offline   Reply With Quote
Old 09-20-2010, 02:18 AM   #14
El Jay
Gone to greener pastures
Re: Rear end help.
Kevin
I have 2 trucks, both with 4.10:1 rear gears.
Both turn about 3000-3100 RPM at 65 MPH.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 09-20-2010, 02:29 AM   #15
FLEET72
FLEET72's Avatar
Re: Rear end help.
I have 3.07s with 29.5" tall tires ~2400 @ 65mph
http://www.ringpinion.com/Calc_RPM.aspx
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 09-20-2010, 08:30 AM   #16
68Stepbed
68Stepbed's Avatar
Re: Rear end help.
My 350/TH350/3.73 combo with 28" tires runs about 3300 at 65. 3.07 gears are more highway friendly. I say go with the 3.42 gear and have a compromise of 3.73 and 3.07 gears.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-20-2010, 03:49 PM   #17
Shaky
Shaky's Avatar
Re: Rear end help.
I like this compromise if you're gonna go with the TH350.
