axle shaft question
Are there any stock junkyard axle shafts that will bolt into my 66 suburban rear diff? I want to go from 6 bolt to 5 bolt.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: axle shaft question
I believe I answered this question in your other thread asking basically the same question
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-19-2010 at 12:42 AM. |
Actually...no. What I want to know is if any axles will fit the existing diff to make it a 5 bolt pattern. I got a private message telling me what will work, so its ok captain...thanks .
#4 | |
Senior Car Nut
![]() Join Date: Jan 2008
If it's some other "secret", there are probably hundreds of us who would truly appreciate being enlightened-please share the info
Larry Last edited by fleetsidelarry; 09-19-2010 at 08:55 AM. |
ya you are right about the 71-72 axles thing... I guess the easiest and least expensive for me is to take the rear diff from my 85 and mount it in.. But has anyone done this on a suburban body and been able to use the stock 8 inch gm truck rally wheels? The fact that the diff is 1.5 inch wider has me nervous...is there lots of room back there for the extra width and wider rim??
Senior Car Nut
double posted-don't know what happened
Larry Last edited by fleetsidelarry; 09-19-2010 at 05:04 PM. Reason: double post |
If overall width is a concern, have a machine shop redrill your 65 shafts to the 5 lug pattern. This should cost less than buying the aftermarket 5 lug shafts.
Ray |
Well that was my original idea but they won't do that here because they say it will take the integrity away from the axle hub area
#9 | |
Senior Car Nut
sorry about the earlier double post, I must have pushed a wrong button
Larry |
#10 | |
fan of "Butters" Stotch
http://www.moserengineering.com/moser/shop-services/ I've never done this myself, but have heard great things about them with this service.
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again ![]() |
I have my 85 chevy coming home soon so i will be able to measure the width of the diff with rims installed, this should help to figure this out. Thanks for the knowledge guys. This is one cool website!
