454 implant
going to drop a 454 in one of our trucks. are bb mounts all i need to worry about. anyone know of a thread that mite help or just some advice maybe? thanx rich
Re: 454 implant
Just motor mounts and front end brackets for Alternator, pump... A/C its fairly easy.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
454 MAKES IT ROAR
Re: 454 implant
It's important to have a new 4 core radiator to keep things sweet.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Junior Member
Re: 454 implant
What transmisson are you going to use?
I am running a three core radiator with a manual transmission, but with a automatic a 4 core would be better as posted above.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Re: 454 implant
Make sure u have actual bb motor mounts. I bought new perches and used small block mounts because we couldn't find any bb mounts. Big Blocks run hot, go ahead and upgrade the cooling system now!!! Install roller rocker arms. Upgrade your mufflers, big blocks r loud (very loud). I guess that depends on your neighbors, lol. Make sure your tranny can handle the new torque or install one that can. Use a short water pump and pulleys if u can, much better with space available. Big block radiator shroud.
Hell, go ahead and spend about 20 grand, lol. Front coil springs need to be changed also. |
AMERICAN IRON ADDICT
Re: 454 implant
If your truck is a 67, you need to trim the top's of the frame rails a couple of inch's for exhaust manifold (header) clearance.
Re: 454 implant
Sent you a PM.
Brad handshoe |
Re: 454 implant
thanx fof all the advice guys. motor has been rebuilt but still pretty stock i think. think im goin to drop it in and run it awhile just cause i can
