09-19-2010, 08:51 AM | #1 |
Using my A/C cab with non A/C heater box?
My 70 truck came with the A/C setup but I don't want to use that stuff. I haven't pulled the system out of the cab or off the firewall yet. There's a member selling a nice non A/C heater box that's about an hour from me for a good price so I'm just trying to get some answers so I don't hold him up. Assuming the non A/C heater box will bolt right in, is there any reason I shouldn't buy his setup and put it in my truck and then sell my A/C heater box set up complete? Or am I wasting my money and I could just take the stuff I need from my A/C setup now and break it up and use the heater box and blower and sell just the A/C portion of my set up? I hope that made sense!
Thanks, Neil |
09-19-2010, 03:53 PM | #2 |
Re: Using my A/C cab with non A/C heater box?
this it what i find IMO need modification,
09-19-2010, 04:44 PM | #3 |
You don't have to modify the firewall. I put factory A/C in my non-A/C truck with no modifications. Everything works fine. The cold is cold and the hot is...well...ROASTING! I think the larger hole has something to do with more airflow or something. I'm not sure why GM made them different.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! Last edited by Dark Knight; 09-19-2010 at 04:44 PM. |
09-19-2010, 07:46 PM | #4 |
But my question is do I just break up my A/C and heat setup to just use the heater box or is it better for me to just use a non A/C heater box and sell my A/C and heat set up complete. I'm not concerned about the firewall just want to know if I'm wasting money buying a non A/C heater box setup instead of just using what I currently have.
09-19-2010, 10:33 PM | #5 |
Why not use a A/C delete plate and all your internal cab stuff and sell your A/C under hood box? Then you won't need a non a/c under hood box. No mods to the firewall this way which you will need to put the non-ac box in.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
09-21-2010, 09:28 PM | #6 |
Sammy just so I'm clear. I can use my current heater box and slap an A/C delete plate on the firewall and just unmount the A/C stuff under the hood and all will still function correctly? So in short I would be wasting my money buying another non A/C heat setup. Right? Ok thanks!
09-21-2010, 11:05 PM | #7 |
Of course your A/C stuff wouldn't work because you have that all disconnected. But yes everything else would be stock looking like with A/c in the cab. I've done this in my 71 GMC. Makes a real clean engine compartment this way. I can get you a pic of mine if you would like to see what it looks like.
09-21-2010, 11:11 PM | #8 |
Sammy thanks for info and yes pics would be appreciated. And I definitely understood before I ever even posted this thread that my A/C would not work. LOL Neil
09-21-2010, 11:12 PM | #9 |
Here is a old pic I had on the puter.
