what would you recomend
im gonna build either a 355 or a 383cu in the near future when $ lets me. but i can decide between the world sr torquers, and the dart iron eagle cylinder heads also i cant decide what size chamber. i think the choices are 67/76cc for the sr heads and 64/72cc for the iron eagles so what would you buy there in the same price ranges. or pritty close
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
if you go with the 383..I would go for the 72cc Iron eagles...for the 355..either the 64cc or 72cc Iron eagle..depending on CR you need to run
JIm
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
If I had to pick between the two I would say the iron eagles, they are a better flowing head. The chamber size mostly depends on what kind of pistons you are running (flat top, dished, ect.). For a street motor, you want to pick a chamber size that will keep you under 10:1 compression so that you don't have to run high octane gas (especially that way gas prices are going up these days!)
67 Chevy SWB - goal of a 1,000 hp weekend cruiser |
