lowering my 69 c/10 (need info)
Hi, was wantin some info on lowering my 69 c/10. it has coil springs in the back. I've seen the spindles on ebay, there 2.5 drop. also the coil springs, there all different sizes. my rear sits a little lower than the front now. my question is what all do I need to lower my truck. Guess i'll go for a 2.5 drop. Also what size tires and wheels will work at that height. Thanks for any info
Insert Title Here
Re: lowering my 69 c/10 (need info)
If you still have drums up front, you cant just use the spindles, you need to convert to disc... Mine has 3 inch springs all around, and a 2" block in back with 4 wheel drums still
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 09-19-2010 at 01:50 PM. |
Thanks, yea i have already changed to disc brakes and 5 lug rotors
Tot Roddin'
Jesse, as far as lowering your truck, it's going to depend on how "low" you want to go, and your budget.
Minimal lowering 2/4: 2" front springs 4" rear springs Option - New shocks and shock relocators (Some consider running a 3" spring, also an option but the shocks and relocators will be a must IMO) Lower: 2.5" drop spindles (Matched with a 1-3" drop spring) 5 or 6" drop springs (optional bolt in c-notch - NOT REQUIRED) New lowered shocks Shock relocators Super-trac Bar (aligns the rearend back up) Lowest: Bags or Dropmember Wheels: This is kind of a free for all. I've ran stock wheels, ralleys and larger dia. wheels. You will get a million different responses, you just have to make sure they will not bottom out on the inner fenders (front or rear). For a step by step install check out my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=353633 Here's my truck staticly dropped 4.5/6" without the need of a c-notch:
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 09-19-2010 at 08:54 PM. |
Super Nice!!! What size tires and rims do you have on your truck, they look great fill up the fender wells perfect
Tot Roddin'
All specs are in my build thread listed above, as well as in my signature.
They are 20x8.5 and 20x10 w/ 255/40 and 295/40 respectively.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
