Old 09-19-2010, 01:07 PM   #1
jasonroman
jasonroman's Avatar
headers....should be run with true duals only?
well a while back, i went through exhaust nightmare. but at the time i didnt have headers so, i just had guy put on a new cat back exhaust.
i just picked up a set of headers. and looked for a couple prices on getting them put on.
one guy told me 300 to make headers work with my current exhaust.
which is manifolds, a y pipe i guess. that go into, new cat, new pipe to muffler, and at muffler i have two pipes running out and exiting behind rear wheels
another shop told me theres no point tying into the current piping. headers should be run tru dual, for power and performance.
no price yet, needs to look at it....
3rd shop, guy told me today around 800 plus whatever is involved getting the manifolds off....
800, dont have it, but if i did, i think id spend it on lowering my truck rather than doing the exhaust a 2nd time.
first time ran me 500 and alot of headache.
looking for info or advice.
unfortunateley i am not much of a mechanic at all, so i dont think ill try cutting off new piping and re piping myself.
jasonroman is offline   Reply With Quote
Old 09-19-2010, 02:44 PM   #2
BlueMagicSS
Re: headers....should be run with true duals only?
You can run headers without True Duals. Unless you have a lot of mods it's better to use the y-pipe because you need backpressure. Your best bet would be to have your current exhaust tie into the headers, it's a matter of cutting and welding.
BlueMagicSS is offline   Reply With Quote
Old 09-19-2010, 02:48 PM   #3
jasonroman
jasonroman's Avatar
well as for mods, i have none at the time.
stock 350. id like to change carb, intake mani and maybe have cam changed.
but right now its all stock.
my old 82 c10 had headers, carb, intake mani, not sure about cams, had 305 heads, and if i got on the gas, id lay a patch 100yrds, this truck, i stand on gas, and theres a lag, and then go, no wheels spin. unless wet...
not 17 looking to leave patches every where.
but i had a similar truck with similar parts, that sounded and ran much stronger.
thats what im looking for in this truck
Old 09-19-2010, 02:55 PM   #4
BlueMagicSS
Yeah... at this point if you go TD's you'd lose more power. At least on the low end.
Old 09-19-2010, 02:57 PM   #5
jasonroman
jasonroman's Avatar
so you suggest i keep my current system and have the headers tied into whats existing?
last thing i want to do is loose power im trying to find.
Old 09-19-2010, 04:09 PM   #6
slugish
Slugish
you will be fine tying your existing exhaust into your headers. Ive got a warmed up 400 ,3in. to the muffler & 2 -2.5 pies exiting the back . Many reputable gearheads told me this was plenty of flow for what Ihad . True duals may not hurt you that bad ,but certainly wont help you.
slugish is offline   Reply With Quote
Old 09-19-2010, 04:26 PM   #7
jasonroman
jasonroman's Avatar
i guess if it wont hurt thats a good thing. i plan on changing a couple things later on. but i know this much, i dont want to pay to have my exhaust done 3 or 4 times.
thats why im looking for opinions on which way to go.
simple things not big motor mods are in store. dont know enuff and dont have the extra money to go big with the motor.
like i said before, eventually ill get a carb, intake mani, cam.
and then go from there i guess
Old 09-19-2010, 04:38 PM   #8
foamypirate
foamypirate's Avatar
Originally Posted by BlueMagicSS View Post
...because you need backpressure.
When will this myth die?
foamypirate is offline   Reply With Quote
Old 09-19-2010, 04:40 PM   #9
3r!c84
Badass
3r!c84's Avatar
not a myth try running anything open headers it will have a big loss in power.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-19-2010, 04:46 PM   #10
jasonroman
jasonroman's Avatar
and there is my problem....
as a guy who dont know much about motors, hp. or how to make it.
i come to the forums for a little insight.
i get mixed reviews when it comes to my problem.
heard not run the headers with my current set up. total loss. no point and no power gain.
then i heard run what i have, add headers.
Old 09-19-2010, 05:17 PM   #11
Rollie396
someday it will be done!
Rollie396's Avatar
welcome to the internet. If you want the headers on there,then I would go ahead and tie them into your existing system and try it out.Maybe later on down the road you can switch to dual exhaust and try that.You'll then be able to compare the two and know what works best.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 09-19-2010, 05:39 PM   #12
jasonroman
jasonroman's Avatar
yea i guess thats my option
spend 2grand on exhaust 3-4 times....
Old 09-19-2010, 05:51 PM   #13
nbpro
http://books.google.com/books?id=6JI...page&q&f=false
nbpro is offline   Reply With Quote
Old 09-19-2010, 05:55 PM   #14
PRattenbury
Headers can be a head-ache. I can't dispute they improve exhaust flow, which I guess can be a good thing. But if you have an emission system that ties into your exhaust manifolds (A.I.R. system) you have to figure out how to get rid of it or make it work with headers. You have to be careful about your plug wires, because headers are famous for ruining them. You have your O2 sensor to worry about. Then you have to worry about whether or not the improved flow of exhaust due to the headers has thrown your exhaust gas temperature off enough to cause the computer to throw a code. And you have to worry about how close the headers are to your starter motor. Headers kill starter motors. Then you wind up with a class A pain in the tookis trying to get the piping from the collectors to the cat without hitting crossmembers, your floorboard, or hanging down so low it looks like crap. And after all that, unless you bought a high-dollar set of headers made of stainless or ceramic coated, the paint burns off and they look like dog doo in 6 months. On a stock or mild built engine I really think they aren't worth the trouble. Especially on computer controlled engines.
PRattenbury is offline   Reply With Quote
Old 09-19-2010, 08:06 PM   #15
bikes&bowties
bikes&bowties's Avatar
If I ever get an exhaust built for something by a shop on a small clock i would run ramhorn manifolds.. But I like my headers except for leaks that sound bad.
bikes&bowties is offline   Reply With Quote
Old 09-19-2010, 08:07 PM   #16
foamypirate
You don't lose power with open headers because you don't have back pressure; you lose power with open headers because you have no exhaust gas velocity or scavenging effect.
Old 09-19-2010, 11:32 PM   #17
cableguy0
backpressure is a myth. It has nothing to do with the exhaust. bigger pipes will make more power period. header tube size however is very important. due to scavenging.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-20-2010, 12:24 AM   #18
nbpro
the link i put in my post tells you some good info
Old 09-20-2010, 12:58 AM   #19
BigRed76
BigRed76's Avatar
I could not agree more. I recently swapped in a 455 in my '72 Cutlass and have been running open headers for the 50 or so miles ive driven it and you can definitly tell that the open headers are hurting the power, but should have full exhaust by the weekend
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 09-20-2010, 03:15 AM   #20
nbpro
http://www.veryuseful.com/mustang/te...Scavenging.pdf
Old 09-20-2010, 03:15 AM   #21
MTCK
MTCK's Avatar
Throw the headers on a shelf and pull them out once you've done an intake and cam to take advantage of them. I assume there are emissions issues in NJ. Once you put them on I'd look at a y-pipe into a single aftermarket CAT and tie into your existing from there. If you want seat of the pants improvement, regear your rear end with some shorter (numerically higher) gears. Also save up for a heat shield for your starter and some plug wire boots. The little things make a difference.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 09-20-2010, 08:10 AM   #22
BigBlocksRule
Some of you open header myth guys are listening to too many uninformed wannabe old farts spouting "back in the day" knowledge that was never tested.
Dyno and track testing will generally show slight power gains from open headers, I've never seen one lose power.
You're trying to get exhaust gases out the cylinder, why would reverse/backpressure help?
If you've got the big factory exhaust system, two into one would probably be fine on a mild 350.
BigBlocksRule is offline   Reply With Quote
Old 09-20-2010, 11:27 AM   #23
78 Chevyrado
I think most people mean scavenging, they just call it back pressure...
78 Chevyrado is offline   Reply With Quote
Old 09-20-2010, 12:50 PM   #24
BigBlocksRule
^ kinda tough to mix those two up, they're actually the opposite thing...
Old 09-20-2010, 03:30 PM   #25
nbpro
new i was a old fart did not know i was a wannabe i do agree tho
