Old 09-19-2010, 03:03 PM   #1
robgrin
robgrin's Avatar
58 cab with 55 nose
A while back there was a thread on how to convert the hood hinge mounting holes in a 58 cab to fit a 55 hood. Does anyone remember how that was done or can direct me to that thread?
Need more money
robgrin is offline   Reply With Quote
Old 09-19-2010, 08:10 PM   #2
Coronas56
Coronas56's Avatar
Re: 58 cab with 55 nose
http://67-72chevytrucks.com/vboard/s...d.php?t=347878 Here ya go, had it saved, have to do the same...........
Semper Fi!
Coronas56 is offline   Reply With Quote
Old 09-20-2010, 04:02 PM   #3
robgrin
robgrin's Avatar
Thanks a million. This helps allot!!
Need more money
Old 09-20-2010, 04:32 PM   #4
samdjr74
So here's a follow up question, if I need to relocate the holes, how do I install the bolt plate behind the firewall to bolt on the hinges and what should I use for the bolt plate?
samdjr74 is offline   Reply With Quote
Old 09-20-2010, 05:04 PM   #5
robgrin
robgrin's Avatar
well from what I under stand the bolt holes are on the same vertical line so you could just weld some more nuts on the same plate were they need to be. but here is my question. I just went out and measured my holes and they are 2 3/8 on the top hole and 5 3/4 on the bottom. When I bolt the hood on it sets high so the holes would need to be lower but the measurements I have for the holes on a 55 cab are 2 1/4 and 5 1/8 witch would raise the holes. Do I have the wrong measurements for a 55 cab?
Need more money
Old 09-20-2010, 05:10 PM   #6
Russell Ashley
Russell Ashley's Avatar
I just replaced three of the welded on square nuts on my radiator support. I bought some square nuts from the local Ace hardware store for eighty cents each and tacked them in place. They are almost exact but a little thicker, and actually look stronger than the originals. The hood hinge bolts are slightly larger than those but the correct size square nuts are available.
BTW, 2 1/4 and 5 1/8 to the center of the hinge holes is what my 57 measures.
Russell Ashley is offline   Reply With Quote
