Old 09-19-2010, 05:40 PM   #1
1971ls1longbed
1971ls1longbed's Avatar
suspension question
i would like some input on my suspension. i want my 71 longbed to handle like its on rails. its being powered by a turbo ls1 t56 and ford 9". is there anyone here that has done this with there suspension and if so where can i get good suspension.the engine is making about 800hp at the crank
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted
1997 C3500 DRW Ext cab. 454, 4L80E daily driver
1971ls1longbed is offline   Reply With Quote
Old 09-19-2010, 08:41 PM   #2
Scottshotrods
Re: suspension question
Take a look at our products www.scottshotrods.com
Justin
Scottshotrods is offline   Reply With Quote
Old 09-20-2010, 04:07 PM   #3
robnolimit
robnolimit's Avatar
There are many good IFS kits on the market. Our No Limit Wide Ride is good if you are thinking about changing the complete IFS. Just a note, You give up a lot of handling capability right from the start with the long bed. Front/rear weight balance also suffers. The rear trailing arm is very workable. check out some of the discussions in the "make it handle' thread.
robnolimit is offline   Reply With Quote
Old 09-20-2010, 07:22 PM   #4
1971ls1longbed
i know i give up some handling with the lwb but i know i can still surprise alot of people. i did read that post and i did get alot from it. but i would like to know what the best trailing arm and panhard rod setup is.
Old 09-20-2010, 10:10 PM   #5
SCOTI
SCOTI's Avatar
Stock truck arms work well as is w/the addition of some poly bushings up front. Porterbuilts truck arms offer better torsional stiffness for minimal deflection while allowing as much as or more articulation w/out binding & are adjustable for length to get everything as square as possible (another commonly overlooked item). I really like his Panhard bar set-up too as it's adjustable w/o removing.
http://porterbuiltstreetrods.com/site/
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-21-2010, 01:43 PM   #6
jephs422
There are several guys running our front suspension and rear suspension that compete in autocross events around the country, and the reports are very good from the guys that have the rubber on the ground.
Check out the link that Scottshotrods posted and browse around a bit.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 09-22-2010, 03:45 PM   #7
robnolimit
robnolimit's Avatar
The key with these trucks is to get enough caster to make them turn in. You need to be in the 6 to 10 deg range, or all the other stuff won't matter. Next is rear bite, focus on a long, low mounted panhard rod. Big swawbars and soft springs will do you better on the street than stiff springs and reg. swaybars. Spend on shocks. Bilstien inertia-valve is the minimun, or step up to single or double adjustable. When dropping the rear on trailing arms, start with a 2" block first, then shorter spring to get what you want. This will ride & handle better.
Old 09-22-2010, 06:25 PM   #8
SCOTI
SCOTI's Avatar
Good info & it pertains to the orignal posters question about what he currently has vs. telling him to swap everything to new, different stuff.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
