Old 09-19-2010, 06:01 PM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
What is the correct way to measure driveshaft?
I am going to have to lengthen the driveshaft by 2 inches and have been told 72 inches is the max length. Is this the correct was to measure it? Do you just measure the tube only?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-19-2010, 06:18 PM   #2
john
member #16
john's Avatar
Re: What is the correct way to measure driveshaft?
I measure center to center on the bearing caps.
john is offline   Reply With Quote
Old 09-19-2010, 06:36 PM   #3
cdowns
cdowns's Avatar
i always asked the guy workin on the driveshaft exavtly how he wants it measured
Old 09-19-2010, 07:02 PM   #4
GASWAGON
AMERICAN IRON ADDICT
x2!
GASWAGON is offline   Reply With Quote
Old 09-19-2010, 07:52 PM   #5
bigbadchev72
People know me
bigbadchev72's Avatar
My driveshaft guy always wants a center to center of caps, 72" Is a long driveshaft, the longer they are the more they tend to get a "belly" in them when spinning and get out of balance.
X2 on calling and asking how they want it measured
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 09-19-2010, 08:47 PM   #6
fishingjred73
fishingjred73's Avatar
x2 on calling but here's a good pic to go by http://www.dennysdriveshaft.com/how_to_measure.html
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 09-19-2010, 09:27 PM   #7
denny5625
denny5625's Avatar
I just had mine shortened. the driveshaft people told me to place the truck with all the weight on the wheels, slide the front yoke into the back of the tailshaft and then pull it out about 1/2" to 3/4". Then measure center to center of the u-joints front to rear. Worked good for me.
66 el Camino
70 1/2 RS Z-28
71 C10 2wd
72 2 wd Blazer
(2) 72 4 x 4 Blazers
88 24' Mirage 70 mph+
08 Harley Night Train
08 Silverado 4d 4 x 4
denny5625 is offline   Reply With Quote
Old 09-19-2010, 09:35 PM   #8
Arizona oldguy
Arizona oldguy's Avatar
Just had one made for my 67 short bed, I live near Phoenix did a google search for drive shaft shops. Master Shaft is the place I used and they had an on line guide telling you how to measure the length. Good luck
Arizona oldguy is offline   Reply With Quote
Old 09-19-2010, 10:54 PM   #9
Painter D
Painter D's Avatar
Ask whoever you're going to have do the work how "they" want it measured. Different places and different people prefer different ways to get the length desired.
I've got to say the word "different" one more time.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 09-20-2010, 01:59 PM   #10
brad_man_72
the boat guy
brad_man_72's Avatar
end of trans tailshaft to center of ujoint on rear end is a great measurement. That's the measurement we prefer, if it's wrong it's our fault well make it right free.
max driveshaft lenth is mosty limited by driveshaft diameter. 2" diameter would be good for about 40", 3" diameter woud be about 60". Too long or spinning too fast can turn into a jumprope and ruin your day.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
