09-19-2010, 07:48 PM | #1 |
Do I need this
I am upgrading from a Quad-R-Jet carb to the Edelbrock 1406. Do I need this spacer and breather tube when I change??? Will I need some type of filter to replace vent in valve cover??
09-19-2010, 07:49 PM | #2 |
Re: Do I need this
You can go without it. Do you have a PCV in one side and a breather in the other? If yes, then plug the hole. If you are missing the breather, put a breather in that spot.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
09-19-2010, 07:51 PM | #3 |
Grandpa in the rustmobile...
Re: Do I need this
You dont NEED it...But you will need something to plug the hole in valve cover
you need a pcv on one side, and some kind of breahter on the other and a place to put oil in at lol you *may* need some kind of riser to let the air filter clear the dizzy, I did but im running and alum. intake/aftermarket air cleanr
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-19-2010, 07:55 PM | #4 |
Re: Do I need this
Ok Thanks guy the fast response.
