Change from power brakes to non-power?
Ok. I have a '69 with drums and power brakes and I would like to switch to non-power. I have my reasons.
![]() Can I just get a new master, pull the booster and bracket, replace the brake rod (power has a pin on the end and I need the rounded end)? I'm using the truck (striped sheet metal, cab and bed off the truck) for a hotrod/ratrod project. The booster is WAY to big. |
Re: Change from power brakes to non-power?
Should work. Or just buy a smaller diameter booster.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Back in the sticks
Or find someone that wants to reverse the process, like that has a 69 Blazer with regular brakes and is in Bremerton too....
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Grandpa in the rustmobile...
^^ all you need is to switch the brakerod, swap with red71 and yall're set lol..
no really just swap brakerods and give him ur brackets/booster
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
