Old 09-19-2010, 10:38 PM   #1
evobuilder
evobuilder's Avatar
anyone know if the auto parts store carries....
the stud on my power steering resevior? the back stud is broken, and I need to get another.... anyone know if this is something I can get from my local auto parts store, or am I going to have to source from a junk yard?
Thanks!
Evobuilder / Seattle, WA
Hub Garage: www.hubgarage.com/mygarage/evobuilder
evobuilder is offline   Reply With Quote
Old 09-19-2010, 11:07 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: anyone know if the auto parts store carries....
I cant remember if it has a nut on the shaft and is removable?? You may be able to replace it with different hardware and not need the original type stud. For instance, threaded rod and a locknut. Just a suggestion.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 09-19-2010, 11:21 PM   #3
evobuilder
evobuilder's Avatar
good call.... I will just grab a stud and a bolt.... it'll work just the same. Guess I have been in the shop too long today... can't seem to think about simple solutions to simple problems
Old 09-20-2010, 04:06 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Here are a couple of links showing replacement studs if you still want to go that way. May not be the same exact application, but a quick look should determine if it will work:
Amazon.com: 1963-1979 Corvette Power Steering... Amazon.com: 1963-1979 Corvette Power Steering...http://www.lategreatchevy.com/chevy-...roduct_Related
Somebody else may offer them cheaper.
