Chevy Only Tx
Help!!!! Need 64 swb stepside frame width?
I am currently redoing my backhalf and I need some frame width measurements from the very end of frame and somewhere behind the trailing arm crossmember. Want to make sure I get the frame back to specs before I redo my bridge for my air ride. Please let me know also if you are measuring inner to inner or outer to outer. Thanks!!!!!
Chevy Only Tx......... |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Help!!!! Need 64 swb stepside frame width?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 09-20-2010 at 05:24 AM. |
Chevy Only Tx
Damn! Question answered and some....Thanx aerotruk63!!!
The 60-66 GMC/Pontiac guy....
Anyone have prints for the 63-66 GMC frames both long and short wheel base?
I have both chevy and GMC frames and they are very different.
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
UCA63
Different???
they should be pretty much identical other than the WB issue
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
#6 | |
Not exactly sure what your refering to with WB... Wheel base?
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() Last edited by 66-PMD-GMC; 06-04-2011 at 10:24 AM. |
I have a 66 GMC with trailing arm coil spring suspension and it is original......I have another gmc 1965 that is spring.........the frames are not that much different, crossmembers and other items are just in different places. Kieth
Not looking to make or have arguments here.
![]() GMC never had trailing arms 63-66 US built models. ![]() I can not comment on what you have or don't have. ![]() GMC is a different truck than Chevy, never came with a V8 60-66, only a V6, and a Chevy L6 was a special ordered option and the frames are notably different. So different that the Chevy prints not showing spring hangers and cross bracing makes a difference when making a repair or fabbing something up. What I am doing here and the reason I posted to this thread is to simply find someone with 63-66 GMC blueprints as the Chevy prints shown in this thread do not show the difference or have the dimensions that could and probably would help me in my builds. However, the Chevy 4X4 prints for the back half probably are the same as GMC and if someone had those prints it could really help in what I am doing. Check the GMC V6 site online about what is and isn't factory on GMC trucks. They have lots of information on US built GMC models and more.
Hey Kieth,
Just took a look at your 66 build at http://kieth.smugmug.com/Trucks/66-G...67555326_3TbEg And I'll bet dollars to doughnuts that you have a 60-62 frame under that bad boy. The cross rail spacing for the bed will tell it all. 60-62 is wider than the 63-66. Again, not throwing rocks, just checking things out.
My 1966 canadian model lwb stepside has trailing arms and coils, but i always thought the chev and (canadian gmc) trailing arm frames were the same.
You know, I have no idea exactly what Canada built but if I was guessing, and I am, the truck in Kieth's build has an early frame. If it is the X style, as I call it, it would indeed be the early frame. Or it may be a Canadian built truck.
However, US sales literature and many other forms of documentation says 63-66 GMC were shipped out the door with leafs only. I would still like to see a print of the rear section of a 4X4 frame (Chevy) and compare it to my GMC's. I am convinced there are no GMC blueprints available but hope I am wrong.
Yes i agree with you there the older x frames were a different width. If anyone would have the prints of a 4X4 frame (Chevy) and a gmc it would be aerotruk63.
