Old 09-20-2010, 01:40 PM   #1
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Question Help..power steering on a 56??
the truck I'm working on is for an older gentalman and the old manual steering is getting a bit much for him...I'm open to kits or retro fits
thanx
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-21-2010, 02:29 AM   #2
55dude
55dude's Avatar
Re: Help..power steering on a 56??
toyota 4x4 power box off the straight axle trucks 79'-85'.
55dude is offline   Reply With Quote
Old 09-21-2010, 06:58 AM   #3
Hottrucks
Hottrucks's Avatar
yea I know I did that with a straight Axle ford before...any other options?
Old 09-21-2010, 02:07 PM   #4
55dude
55dude's Avatar
how did the conversion on the ford work? what year?
Old 09-21-2010, 03:55 PM   #5
Hottrucks
Hottrucks's Avatar
I have done it on 2 different trucks one was a 54 ford 2 wheel drive and the other is a 66 4X4...both worked flaw less...theres a company that make the new drag link on the box so its a bolt in deal on that end only issue is having to cut the column and add a hind joint to mate up to the box....if you use the ford PS pump you need to add a presure reduser chevy pumps are fine
Old 09-21-2010, 04:04 PM   #6
Hottrucks
Hottrucks's Avatar
heres a link that may help
http://www.f100central.com/steering.html
Old 09-21-2010, 05:23 PM   #7
Russell Ashley
Russell Ashley's Avatar
The only other p/s kit option that I'm aware of is the later Chevy box that mounts outside the frame. Here's a link to a build with a good picture of it.
http://67-72chevytrucks.com/vboard/s...d.php?t=373616
This is not my truck but I have the same kit on mine. This one will also require steering column mods and two Borgeson or similar joints. I have Corvette 8 inch wheels with 235/75/15 tires and they don't rub, but some wheel/tire combo's would.
Russell Ashley is offline   Reply With Quote
Old 09-21-2010, 07:38 PM   #8
drummin89
drummin89's Avatar
also what engine does he have in his truck?
Chris
52 Chevy 3600 (3/4 ton) 5 window pickup
-54 235 Inline 6 w/ Fuel Injection Conversion
-Clifford 2/4bbl Aluminum Intake and Headers
-1/2 ton front axle swap w/ 5lug disc brake kit
-CPP Power Steering Kit
Various pictures of my 52 Chevy 3600
drummin89 is offline   Reply With Quote
Old 09-21-2010, 08:57 PM   #9
Hottrucks
Hottrucks's Avatar
I 6 its the 251
Old 09-22-2010, 03:23 AM   #10
55dude
55dude's Avatar
the reason i lean towards the toyota box is i have seen the chevy conversion and the tire rubbed on the box so that limits your wheel and tire selection with box hanging off outside of frame.
Old 09-22-2010, 09:38 PM   #11
drummin89
drummin89's Avatar
Originally Posted by Hottrucks View Post
I 6 its the 251
I take it you mean 261 I6. If so that creates another whole problem. Let me know what it is as I have a solution if your interested.
Chris
Old 09-23-2010, 06:51 AM   #12
Hottrucks
Hottrucks's Avatar
yea thats what I meant...the days are running together for me
I'm intrested
Jeff
