Old 09-20-2010, 04:32 PM   #1
ryans69chevy
1969 chevy c10 rear end questions
Hey, first post on this site trying to get to know and understand more about my 69 chevy c10 i bought a year ago. I've done alot of work on this thing and now that it's a realiable pickup for travel i'm just looking for some better gas mileage. I've checked into getting brand new gears in my rear end but it was right around 800-1000 to get all that done. i'm looking for a cheaper method hoping to find a used rear end with a 3:08 ratio...right now it's gotta be at least a 3:73 ratio maybe even steeper so my rpms are screaming at 60!
My question is does anyone know what rear end will fit under my 1969 chevy c10 1/2 ton 2wd with coil springs without any modifications? If so, what vehicles will i find them under?
Thanks!
ryans69chevy is offline   Reply With Quote
Old 09-20-2010, 10:35 PM   #2
SCOTI
SCOTI's Avatar
Re: 1969 chevy c10 rear end questions
Thanks!
65-72 rears are all basically the same. They'll interchange & came w/various gear choices as well from 3.07's to 4.11's. You need to find someone selling a rear from these years w/the 3.07's for best milage & easiest install.
Later model truck rears can also work but would require shaving the leaf spring brackets off & welding new truck arm perches on (same thing for a later model car housing). F-bodies are also close in width if you can do the spring perch cut & weld task.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
