09-20-2010, 06:48 PM | #1 |
Van Tilt Shifter
I have a truck tilt column from a 72. I want to replace the shifter to the smaller ones found on van tilts. Would this be a direct swap? If not , what mods would be necessary? Plus what year van tilts would I look for to get the smaller shifter? Thanks Gary
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
09-20-2010, 08:19 PM | #2 |
Re: Van Tilt Shifter
The tilt shifters are a direct swap. Early vans seem to have the truck style shifter so I would suggest looking at 75-81 vans. Also, look at motor homes of the 80's vintage.
It is an easy swap out and you can compare the ends to make sure that you have the right shifter once you pull them out. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
