Old 09-20-2010, 06:55 PM   #1
pwrunt3pte
As exhaust valve is 3/4 of the way from closing, the intake valve starts to open???
I replaced the head gasket on a generation IV 454. after i had it back together it wouldn't start. you could tell there was something wrong because the starter didn't have that usual sound to it like there was no compression. i noticed that when I cycled the engine around with a breaker bar that the intake valve would open, before the exhaust valve had closed all the way. Meaning that they were both open at the same time for a second. I didn't touch the cam, timing chain or gears when i replaced the head gasket. Is this a valve adjustment issue or is the cam miss aligned?
pwrunt3pte is offline   Reply With Quote
Old 09-20-2010, 07:14 PM   #2
magicoolbus
magicoolbus's Avatar
Re: As exhaust valve is 3/4 of the way from closing, the intake valve starts to open?
If you didn't mess with the timing chain, then nothing should be wrong with the cam/crank timing. I suspect that the valve lash is set too tight.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 09-20-2010, 07:27 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
The intake and exhaust are open for a short time. Its overlap for whats called scavaging. It makes sure all the exhaust gets out of the cylinder and chamber. The valves may be out of adjustment and hanging the valves open. Re adjust per the book.
As Magic said if you didn't touch the cam or gears then your ok there. Just concentrate on what you did have your hands on. check the valves, plugs, wires
dwcsr is offline   Reply With Quote
Old 09-21-2010, 12:10 AM   #4
Kim57
Kim57's Avatar
Make sure the distributor isn't misaligned.
Kim
Kim57 is offline   Reply With Quote
Old 09-21-2010, 02:15 AM   #5
Tchia65
Does the exhaust valve ever close? You might have valve guide that slipped out of the bore and hammered itself on to the valve, preventing it from closing. Either that or your lash is WAY too tight.
1958 Fleetside shortbox
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Tchia65 is offline   Reply With Quote
Old 09-21-2010, 07:26 AM   #6
Dan Bowles
AD Addict
If you lost fluid from a lifter, you might have your lash set super tight. I pulled all the plugs and could turn mine over using the fan and I set the lash that way. Socket wrench and feeler gauge. Once it warmed up, did it again and it runs like a dream.
Dan Bowles is offline   Reply With Quote
Old 09-21-2010, 01:15 PM   #7
Tchia65
I prefer the EOIC method, it ensures the lifter is on the base of the cam and not the ramp. Pull all your plugs and rotate the engine until #1 exhaust valve just starts to open. At this point you adjust the intake valve until there is no vertical play (0 lash), it should not be tight, just adjust it until you can't lift the rocker off the push rod tip with light pressure, then tighten another 1/2 turn. Do this to all cylinders in the firing order. Then go back to #1 rotate the engine until the intake opens and starts to close. Adjust the exhaust valve the same way. Do all the ehaust valve in the firing order.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
